stance issue
Old Apr 24, 2008 | 01:02 PM
joe645733's Avatar
joe645733
Default stance issue
hey guys. i dropped my car pretty low, but im constantly hearing a knocking noise from the fronts mostly. any suggestions about what it can be? thanks
Old Apr 24, 2008 | 02:24 PM
JETPILOT's Avatar
JETPILOT
Do they use rubber or urethant bushings? If it's urethane they tend to make a knocking noise when they unload.
JET
Old Apr 24, 2008 | 02:43 PM
j1234's Avatar
j1234
all the coils do this. its because there is no rubber piece in between the top of the spring and the bottom of the spring. look at ur stock components and u will see what i mean. basically makes the noise go away. no if u have OEM type rears then that would explain why its only up front. i have true coils and i get it on all four corners. i wouldnt sweat it.
Old Apr 24, 2008 | 03:26 PM
brigz's Avatar
brigz
Take a wrench and tighten the nut on top of the coilover. Its just under the adjustment ****. That should do the trick. When i got mine it was doing the same thing but i also had to tighten the rears which was a *****. For some reason they come from the factory loose.
Old Apr 24, 2008 | 03:28 PM
philude's Avatar
philude
truth. I did that and it solved the problem, but eventually it came loose again. I'm way to lazy to care, the noise makes me feel like i'm driving a super fast race car, like a true ricer.
Old Apr 24, 2008 | 05:35 PM
joe645733's Avatar
joe645733
yup youre right. i have the true coilovers in the rear and has the rubber bushings in the front. went to stance and they said the same. just tighten the nut.
sherm
Apr 11, 2020 05:21 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
350z82
Oct 1, 2015 06:25 PM
