Rear Brake Backing Plate Removal
I want to remove the rear backing plate for my rear Brembo brakes. I see it is popular to cut it off with a cutting wheel. Is there a proper way to remvoe it completely? Anyone know how?
JET
JET
You will still need the e-brake area of the dust shield (refered to in your inquiry as the backing plate?). I just trimmed the dust shield lip in order for the bigger rotors to clear the dust shield. Most people use tin snips;however, some use a dremel tool with a cut-off wheel. Be careful not to cut brake hoses, e-brake cable, etc. Good Luck!
Use tin snips if you can.
I used a pretty big neumatic cutting wheel and it still took me a while.
You can remove it, but you would need to remove the four bolts behind the knuckle which means the knuckle needs to come off.
The track e-brake vs the other 350Z trim levels is a little different on the 2003 - 05 models (don't know on the 2006 on up); however, their all one piece. I am looking into relocating the e-brake inboard inorder to avoid the e-brake issues in its current location located inside the rotor hub and lighten the rear unsprung weight.
i completely removed the dust shield in the front and rear during my bbk install.
the rear, i removed the caliper, and the rotor, then used metal shears to cut the shield into slices. if you have a wedge or mini crow bar, you can actually cleanly separate the outter shield from the hub since it is a press-fit/glued on just knock it loose, then cut and carefully pry out and it will slide off... there is a backing that is close to the ebrake, i left that there.
JET
JET
Typically, I'd seen in the past that inboard E-brake disks with mechanical calipers are mounted on either side of the axle close to the pumpkin. I don't know if their is adequate room to install a mounting bracket for inboard E-brakes in this location. The rotors/calipers a fairly small size as I recall. The E-brake cables will likely have to be modified as well. I'll check into this and let you know.
