Brembo Brake Line Question
Old May 9, 2008 | 03:59 AM
TEF's Avatar
TEF
Default Brembo Brake Line Question
For those of you that have made the conversion from standard brakes to Brembos, I have a question regarding brake lines as I am a bit confused by the connection of the line to the Brembo caliper. It appears that OEM line connects to Brembo by way of a straight line entering the back of the caliper and held by a flare nut. By contrast, the OEM non-Brembo line connects to non-Brembo caliper at a right angle and is held by a banjo bolt and copper washers. Therefore, it's assumed that brakes lines for Brembo and non-Brembo calipers are different. However, if one buys, say, StopTech aftermarket braided SS lines, it appears that the same line (with banjo-style end) fits both types of caliper. Moreover, I seem to recall a member posting something saying that the existing non-Brembo lines work fine when installing Brembos.
I am sure there are a number readers that have made this conversion and can explain how lines are connected to the Brembo calipers.
Thanks in advance for your assistance with this.
Old May 9, 2008 | 05:28 AM
Neb's Avatar
Neb
I'm kind of curious about this myself. I would like to make the switch as well one day.
Old May 9, 2008 | 06:06 AM
z-u-later's Avatar
z-u-later
Brake lines are the same for non-Brembo & Brembo. I just converted from non-Brembo to Brembo and I did not have to change my stainless steel brake lines.
Old May 9, 2008 | 08:47 PM
rromero's Avatar
rromero
Same here. I didnt buy any new brake lines when the installed the calipers. they used the oem .
Old May 13, 2008 | 12:51 PM
Carbon-Z's Avatar
Carbon-Z
Sleeps in 350Z
That's strange, when we received some lines from a vendor on here they sent us the wrong ones for the non-brembo Z and we tried to use them and they wouldn't work. The end bolts were too long. We had to send them back and get the Brembo ones which worked just fine.
Old May 14, 2008 | 09:38 AM
z-u-later's Avatar
z-u-later
That's the key -- it was probably the wrong ones in the first place. Last year, I replaced my stock '06 rubber brake lines with stainless steel brake lines. When I recently upgraded to Brembos, I used the same stainless steel brake lines without issues.
Old May 14, 2008 | 10:26 AM
Carbon-Z's Avatar
Carbon-Z
Sleeps in 350Z
Well the ones we received were for the non-brembo Z. And wouldn't fit the Brembo one.
Old May 14, 2008 | 10:44 AM
StopTechErik's Avatar
StopTechErik
Vendor - Former Vendor
The stoptech lines have you remove the hard line fitting that comes out of the Brembo caliper letting you use the same line for Brembo and standard cars:
http://www.stoptech.com/tech_info/ma...A_10-25-04.pdf
I actually no longer work with StopTech, just havent changed my screenname yet
Old Jul 8, 2008 | 10:45 PM
LaoSiFu's Avatar
LaoSiFu
For the folks that didn't need new brake lines when they upgrade to Brembo, do you guys have the 03-05 Z or the 06+?
~Robert
Old Jul 9, 2008 | 05:17 AM
z-u-later's Avatar
z-u-later
I have an '06 . . .
issyz
Jul 2, 2017 03:04 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
samansharif
Sep 25, 2015 12:31 PM
