HELP Rotor Stuck
Old May 15, 2008 | 09:27 AM
ttuberz's Avatar
ttuberz
Default HELP Rotor Stuck
Alright so I'm trying to replace a stud and i was following the DIY on how to do it. I took off the brackets for the caliper and now the rotor is supposed to slide right off. I used a rubber mallet, wd40, kept pulling but it just won't even move. Is there another method to remove the rotor. BTW its the passenger rear. Any help would be appreciated.
Old May 15, 2008 | 09:44 AM
VO...'s Avatar
VO...
Administrator
Make sure your parking brake is off. If it is, keep beating the $hit out of the back of the rotor evenly around. It'll come off....
Old May 15, 2008 | 09:45 AM
Spray with some penetrating fluid. Let sit for 10 minutes. Do you have access from the rear? I suppose that you do not want to damage the rotor. Place a 2x4 against the back of the rotor. Hit it with a big steel hammer.
Old May 15, 2008 | 10:38 AM
ttuberz's Avatar
ttuberz
Yea i did make sure the parking brake was off. I guess I will have to keep beating it than. I wasn't sure if there are any other bolts holding it in place. Id rather not risk damaging the rotor with a big steel hammer lol.
Old May 15, 2008 | 10:42 AM
07rdsterGT's Avatar
07rdsterGT
Think about this man. RUBBER, bounces. Therefore you are transferring NO energy. You need a dead blow (which is made of rubber, BUT, it's different, it won't bounce back, therefore the energy is being transfered to the rotor, not staying in the rubber mallet.) And personally, I always use a small sledge to knock rotors loose. Just wrap the sledge with a cloth or shirt.
Old May 15, 2008 | 10:46 AM
VO...'s Avatar
VO...
Administrator
Yeah man, just keep beating the crap out of it. It'll come off eventually...
Old May 15, 2008 | 12:04 PM
ttuberz's Avatar
ttuberz
I put everything back together since I needed the car but I'm going to attempt this in the morning again. Thanks for the help guys.
Old May 15, 2008 | 12:10 PM
UMW350Z's Avatar
UMW350Z
do NOT just wrap with a measly shirt or cloth....that is a great way to mess up the rotor
Old May 16, 2008 | 08:03 AM
VO...'s Avatar
VO...
Administrator
updates?
Old May 16, 2008 | 10:10 AM
ttuberz's Avatar
ttuberz
I got it off by beating at it like you said. I used a block of wood and hit the wood to transfer the energy to the rotor since the rubber malllet didn't work. Thanks again for the help!
Old May 16, 2008 | 11:49 AM
350ZTheStandard's Avatar
350ZTheStandard
It was rusted on right???
Old May 17, 2008 | 10:00 PM
ttuberz's Avatar
ttuberz
I guess so. 5 yrs of ownership and and it felt like I was trying to fix a 30 yr old car lol.
Old May 19, 2008 | 02:48 AM
07rdsterGT's Avatar
07rdsterGT
Rotors rust within seconds of coming into contact with water. Don't feel like it a 30 y/o car! If it were that old you wouldn't have gotten the rotor off! LOL
UMW350Z - Well, if you use the whole tshirt there is plenty of padding there. I've done it a million times on various cars and trucks. And it takes me only a few second to pop a rotor off.
Old May 19, 2008 | 08:55 AM
DVFlyer's Avatar
DVFlyer
Speed of White
FWIW- I had a stuck rotor when I did my front brakes. My neighbor came by and saw me trying to hit the back side of the rotor to knock it loose (not a lot of room to swing the hammer). He took a block of wood and a hammer and smacked the FRONT (outer) side of the rotor... and it popped right off.
Old May 19, 2008 | 11:51 AM
VO...'s Avatar
VO...
Administrator
Old May 19, 2008 | 12:18 PM
A big hammer is good.
Old May 21, 2008 | 06:38 PM
35Z's Avatar
35Z
Buy or rent (available from most auto stores) a brake puller.
Old May 21, 2008 | 07:55 PM
ttuberz's Avatar
ttuberz
I already got it off! lol...Dam i didn't even know theres a thing called a brake puller. Good to know. Thanks.
As far as a big hammer is concerned, i should have used the one in my pants haha jk
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Stevo Z
Oct 3, 2015 09:14 PM
samansharif
Sep 25, 2015 12:31 PM
Beater350z
Sep 9, 2015 03:36 PM
