Wierd noise from rear when i slow down. (Not Squeaking noise)
Old May 29, 2008 | 12:41 AM
scoobydude's Avatar
scoobydude
Cool Wierd noise from rear when i slow down. (Not Squeaking noise)
ok. The sound is from my passenger side rear. when i slow down(press brake) i hear little tapping noise and some metal grinding sound. I dont hear the noise when im cruising. but when i go about 5~10 mph and slow down, i hear the noise. I think I hear it after i repaired my Z. Few weeks back, i hit curb and I replaced the bent/broken parts. maybe its because of that accident, but i dont know what to do with it.
Old May 29, 2008 | 02:07 PM
scoobydude's Avatar
scoobydude
Please help~
Old May 30, 2008 | 11:32 AM
j.arnaldo's Avatar
j.arnaldo
Pad wear indicators??? Is there a slight thumping? Check pad thickness. Otherwise, it's Repair Shop time. Good luck!
Old May 30, 2008 | 12:25 PM
RedBullRR's Avatar
RedBullRR
Change your brake pads.
Old Jun 3, 2008 | 02:23 AM
scoobydude's Avatar
scoobydude
but the sound is from only rear right side;
Old Jun 3, 2008 | 04:16 AM
35Z's Avatar
35Z
Default Rear Passenger Side Noise
SDUDE:
Is the noise the same side that you hit a curb? How many miles on your Z? Have you ever had the "clicking rear axle TSB" service done? Is the noise a grinding noise or?
Jack up the rear passenger side so the rear tire is off the ground and wiggle the tire/rim. If it wiggles, the wheel bearing may be out of round. If so, its replacement item.
Old Jun 3, 2008 | 04:29 AM
RedBullRR's Avatar
RedBullRR
Have you at least checked the pads?
Old Jun 3, 2008 | 03:15 PM
scoobydude's Avatar
scoobydude
I dont think its brake pad since it has some left. I would like to say the sound is more like a grinding sound, and sometimes it wiggles. so I should go and check the wheel bearing?
Old Jun 3, 2008 | 05:24 PM
35Z's Avatar
35Z
Yes SDUDE.. Check the wheel bearing on the rear passenger side first!
Obadabot
Jun 18, 2023 11:31 PM
wanderingstuden
Jan 28, 2016 07:03 PM
