crazy brake wear please help!
Old Jun 27, 2008 | 09:52 PM
zmespeed's Avatar
zmespeed
Default crazy brake wear please help!
ok, i do drive very spirited quite often and probably drive it in track like conditions. but the inside of my rotors wear much faster than the out side. ive gotten them hot enough to glow and smoke, so i know they've seen more heat than there suppose to but the inside of the brake is where the most wear is . the outside close to perfict. this is happeing to all my brakes but the rear did this plus cracked in two places fronts just have micro cracks.
brakes are standard none brembo 2003 with the stoptech stage 2 upgrade with hawk hps pads or something close to that name
close up of in side rotor
Old Jun 27, 2008 | 09:54 PM
zmespeed's Avatar
zmespeed
1 in side rotor close up....2 in side rotor...3 out side pad 4...inside pad ...5 inside pad
Attached Thumbnails crazy brake wear please help!-cimg2136.jpg   crazy brake wear please help!-cimg2137.jpg   crazy brake wear please help!-cimg2141.jpg   crazy brake wear please help!-cimg2142.jpg   crazy brake wear please help!-cimg2143.jpg
Old Jun 27, 2008 | 09:56 PM
zmespeed's Avatar
zmespeed
first inside pad ....2, out side rotor...3 in side pad on rotor....4 out side rotor close up
Attached Thumbnails crazy brake wear please help!-cimg2144.jpg   crazy brake wear please help!-cimg2146.jpg   crazy brake wear please help!-cimg2145.jpg   crazy brake wear please help!-cimg2147.jpg
Old Jun 27, 2008 | 09:58 PM
zmespeed's Avatar
zmespeed
these are pix of the micro cracks on the front... i know i need brembo but they wont fit in on my 17inch rim so its huge $$ to get them ...rubber 1k rim 2k brembo 1.5k total 4.5k
Attached Thumbnails crazy brake wear please help!-cimg2148.jpg   crazy brake wear please help!-cimg2148_2.jpg
Old Jun 27, 2008 | 10:01 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
how......damm that's bad man...
Old Jun 27, 2008 | 10:49 PM
Here is a technical explanation: http://www.connact.com/~kgross/FAQ/brakepad.html
Old Jun 27, 2008 | 11:04 PM
zmespeed's Avatar
zmespeed
that was quite helpfull but the z's front calipers are located in front of the axle does this just mean the car toes in under brakeing
"Differences in wear between the inner and outer pads arise for two different reasons. The first is a car's tendency to "toe out" under breaking, that is, for the front half of a tire to move outward, the rear half inward. Because of this tendency, we compensate by giving cars a little toe-in in their alignment. This toeing places a little more load on the inner pad in a caliper mounted behind the axle."
Old Jun 27, 2008 | 11:13 PM
JETPILOT's Avatar
JETPILOT
Single piston floating calipers will wear like that. There is only one piston on the inside. You are way overheating those pads!
Your going to get brake failure and kill yourself on the street or maybe someone else. Maybe even someone you know. The street isn't the place for that.
Old Jun 27, 2008 | 11:24 PM
ZTEALTH's Avatar
ZTEALTH
throw those rotors out or if they are turnable, have them turned (to me they look dead) or buy new rotors. buy new pads. save the racing for the track.
Old Jun 27, 2008 | 11:43 PM
zmespeed's Avatar
zmespeed
i dont race on the street.. but some times in very lowy populationed area's ill drive the crap out of the car for one minute or two. you can feel the stage of fade the brakes are in so i wont let them get to that point. i dont go 150 and hit the brakes its just lots of 70 to 40 braking.
i think im just going to turn them.
Old Jun 28, 2008 | 01:35 AM
terrasmak's Avatar
I believe you only need 5 or 10mm spacers to use your factory 17's with brembo's. You need bigger rotors for what your doing.
Old Jun 28, 2008 | 01:57 AM
zmespeed's Avatar
zmespeed
will the stock brembo's be big enough?
Old Jun 28, 2008 | 03:22 AM
Tac-M's Avatar
Tac-M
i would get this
http://bigbrakeparts.net/catalog/pro...s.php?id=10900
http://bigbrakeparts.net/catalog/pro...s.php?id=12522
http://bigbrakeparts.net/catalog/pro...ls.php?id=8872
http://bigbrakeparts.net/catalog/pro...ls.php?id=5077
http://bigbrakeparts.net/catalog/pro...ls.php?id=5259
http://bigbrakeparts.net/catalog/pro...ls.php?id=2265
Old Jun 28, 2008 | 03:29 AM
Z04's Avatar
Z04
he says he has a stoptech stage 2, so he already should have lines and fluid. thing is, i have non-brembos and i drive pretty hard and never had rotors/brakes look like that.
Old Jun 28, 2008 | 03:41 AM
Tac-M's Avatar
Tac-M
oops, i didn't see that ... SLOW down homie !!!
Old Jun 28, 2008 | 03:43 AM
zmespeed's Avatar
zmespeed
lol thats exaclty the problem... i need to not slow down so much !
Old Jun 28, 2008 | 03:47 AM
Tac-M's Avatar
Tac-M
in that case
a. you are braking wrong , ie riding the brakes to much
b. you need a bbk
Old Jun 28, 2008 | 03:49 AM
Z04's Avatar
Z04
it's early, not enough coffee yet but nice list of parts though, that would be a decent set up
Old Jun 28, 2008 | 03:55 AM
Tac-M's Avatar
Tac-M
thanks !
i am looking at that for my track days... only with race pads... and dbas @ all 4
Old Jun 28, 2008 | 04:01 AM
zmespeed's Avatar
zmespeed
in that case
b. you need a bbk
no im not riding the brakes. i also healtoe every time i slow down using the engine to help.
