View Poll Results: What do you think about an Infiniti BBK on a 350Z
Voters: 36. You may not vote on this poll
What are your thoughts an Infiniti BBK on a 350z
no one said it won't work...we already know it works. No one knows how well it works
The rotor sizes don't differ much between kits, that is true...but that's just 1 aspect. Caliper size has nothing to do with it, it's all about the piston diameter being used in the calipers that determines how it's going to behave with the master, as well as how it will interact with the rear brakes
Originally Posted by Jeff92se
The oem rotors weigh a ton but at least you know the kit was developed with the right bias vs whatever other BBK makers come up with (Stop Tech excluded)
I was contemplating the rear kit to go with my 13" Stoptech front. Looked at the specs for the G37S rear brakes and the rotors are 13.8" and the pistons are 41.3mm. Does anyone know what the piston sizing is on the ST-22 caliper? From initial glance at the numbers it doesn't seem the rear kit will work too well with my 13" ST-40 front setup.
If anyone else is interested here's the numbers on the G37S brakes.
Front brake
Cylinder bore diameter 41.3 (1.626) × 2 + 44.45 (1.750) × 2
Pad length × width × thickness 123.2 × 55.0 × 11.0 (4.85 × 2.165 × 0.433)
Rotor outer diameter × thickness 355 × 32.0 (13.98 × 1.260)
Rear brake
Pad length × width × thickness 95.8 × 41.5 × 9.5 (3.772 × 1.634 × 0.374)
Rotor outer diameter × thickness 350 × 20.0 (13.78 × 0.787)
Master cylinder Cylinder bore diameter 25.4 (1)
Control valve Valve type Electric brake force distribution
Brake booster Diaphragm diameter
Primary: 230 (9)
Secondary: 205 (8)
Recommended brake fluid DOT 3
Front brake
Rear brake
Primary: 230 (9)
Secondary: 205 (8)
Originally Posted by meatbag
Developed with the right bias for a G37s.
Let's see the bias numbers for the other various bbk kits out there.
Originally Posted by Z1 Performance
well you never "need" to swap your master or booster with any BBK....doesn't mean that it was designed with the master and booster from your car in order to operate as its intended. With something as critical as brakes, it's worth heavily researching, and doing the math so you know for sure, vs guessing
FYI:
Go/phone the the parts dept. at the Infinity dealership to determine whether the brake booster (likely) and brake master cylinder (unlikely) is a different spec/part number. Have the Parts Dept. cross-reference the spec/part number of these parts to determine whether they are different then the ones on you Z and post the information.
Good Luck!!
But even in the worst case scenario, if this combo of a 13" BBK in the front would have a disbalance with the G37 rear brakes, would a brake proportioning valve take care of this?
They are only, what, like 100$ a piece?
seagrasser
Oct 11, 2015 03:27 PM
