what front camber arm are you guys running?
Old Jul 9, 2008 | 02:24 PM
finalforce's Avatar
finalforce
SPC, best bang for the buck.
Old Jul 9, 2008 | 07:59 PM
labelworkshop75's Avatar
labelworkshop75
Spl
Old Jul 10, 2008 | 01:08 AM
brigz's Avatar
brigz
cusco a arms here
Old Jul 10, 2008 | 11:36 AM
eze-edsel's Avatar
eze-edsel
is there anyone else running battleversion rear cambers? if so what front did you go with? it seems that most members have spl, but IMO they are cheap looking and not very strong compaired to cusco.
Old Jul 10, 2008 | 11:38 AM
blasian's Avatar
blasian
My SPL rear camber arms look far from cheap and appear to be very strong compared to stock.
Old Jul 10, 2008 | 11:40 AM
OH6 G35's Avatar
OH6 G35
Wow...cheap looking...
Quite a statement!
Old Jul 10, 2008 | 12:41 PM
redlude97's Avatar
redlude97
I would rather the rear camber arm gives and bends absorbing the force in an impact rather than having a super strong rear camber arm that transfers all that force to the subframe where replacement is much more expensive
Old Jul 11, 2008 | 06:30 AM
eze-edsel's Avatar
eze-edsel
thats a good point I never thought of that. thanks for the info
Old Jul 11, 2008 | 06:49 AM
trodis's Avatar
trodis
Originally Posted by JETPILOT
The best A arms are the www.350evo.com arms. They have solid bushings to compliment the sherical bearings you have on the Battle Version camber arms. if the solid bushings aren't important the nget something cheaper. They also have a large range of adjustment. Don't forget to install SPC toe bolts if you need them.
For the street you should run approx -1 degree of camber.
$850 for front A-arms?!
Old Jul 12, 2008 | 10:18 AM
sfarrah's Avatar
sfarrah
SPL Pro front Camber/Caster arms, rear camber arms plus their rear mid links with Swift springs. These items are high quality, well engineered pieces.
Old Jul 12, 2008 | 02:49 PM
Axelerate's Avatar
Axelerate
Cheap looking???
I much rather have a threaded camber adjuster than a slider. I have SPL and I beat the crap out of them and change my camber setting quite often. Never had any problems, and they adjust with ease.
Old Jul 12, 2008 | 04:13 PM
OH6 G35's Avatar
OH6 G35
+++++1 ...I couldn't agree with you more!
I'm running the "exact" same set-up and I am very pleased and confident of these Performance Parts!!
Old Jul 12, 2008 | 04:15 PM
OH6 G35's Avatar
OH6 G35
I assume that the Springs and Shocks would take care of most of these
Impact Forces??
Old Jul 12, 2008 | 04:18 PM
theZslaw's Avatar
theZslaw
Cusco!!!!!!!!!
Old Jul 12, 2008 | 05:37 PM
redlude97's Avatar
redlude97
Impact Forces??
So then why the need for super strong camber arms? Most people I've seen that damaged their camber arms drifted their rear wheels into a curb, which has always caused the camber arm to bend. If instead it didn't give, the situation above would have occured, the springs can't absorb a shock in that direction.
Old Jul 12, 2008 | 09:52 PM
JETPILOT's Avatar
JETPILOT
Yeah.... well they're forged aluminum with solid bushings. It never made much sense to me to replace the OEm aluminum arms with steel. Nissan took the time to give us aluminum so I decided to stick with it.
emooheo
Oct 14, 2015 08:58 AM
seagrasser
Oct 11, 2015 03:27 PM
CJs_Z33
Sep 18, 2015 12:06 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
