Parking brake light shows up at takeoff...
Old Jul 22, 2008 | 04:53 PM
hotfiyah's Avatar
hotfiyah
Default Parking brake light shows up at takeoff...
what the hell is going on? at first it would go away after a second or two, but lately it's been staying on. i'd have to be at a complete stop before it would turn off...and today i was in a rush for my english class...so i was going bout 75, thinking..."goddamn...i might need a new parking brake". it's not in effect however. the light is just on...
anyone got any ideas?
Old Jul 22, 2008 | 05:56 PM
roast's Avatar
roast
brake fluid is low and/or brake pads are worn.... topping off the brake fluid is the easiest thing to do... but you should most definitely check the pads first.... you don't want to top off the fluid only to have to replace the pads a short while later and have to remove brake fluid to keep it from overflowing when the pistons are pushed back in to accommodate the thicker pads.....
Old Jul 23, 2008 | 11:52 AM
hotfiyah's Avatar
hotfiyah
brake fluid is causing it? i just figured a sensor was getting thrown outta alignment when i accelerated quickly. wow. but that makes a little bit of sense i supose...i'll definitely check it out...
Old Jul 23, 2008 | 10:35 PM
goldenboi1's Avatar
goldenboi1
Default light
sounds like pads are wearing out. don't fill it with fluid before checking brake pads first. if you do fill, you will only be taking fluid out again when you change your pads. unless its leaking brake fluid?
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
