SPC rear camber/toe Kit
Old Jul 27, 2008 | 12:43 PM
chocobo308's Avatar
chocobo308
Default SPC rear camber/toe Kit
Hey guys,
I'm planning on getting the SPC rear camber/to kit after some advice you guys gave me. However, after doing some more research I found out that in the installation of this kit you will have to do some drilling with a dremel or rotary tool. Could someone explain to me what this is all about. I'm kinda nervous about doing any type body alterations to my Z. Thanks in advance
This is a line of instructions I got from a random site:
"Mark area to elongate hole with template provided and use #85126 Rotary file or equivalent to elongate slot. Check to make sure hole is the right size by placing the new bolt with a cam on the head into the hole, it should rotate 360 degrees."
Old Jul 27, 2008 | 12:46 PM
haeshik's Avatar
haeshik
https://my350z.com/forum/brakes-susp...tallation.html
https://my350z.com/forum/brakes-susp...one-wrong.html
if you searched, you should find plenty of info. on this subject. good luck
samansharif
Sep 25, 2015 12:31 PM
