noooob question
Old Jul 28, 2008 | 08:22 PM
_NIZMO_'s Avatar
_NIZMO_
Red face noooob question
go ahead and make fun of this post......but I wanna do this thing right.........so I'm still waiting on my coilovers......but was wondering how the proper way would be to raise the front of the Z and get it on some jack stands.......the rear is easy, sense there is a rear differential....
I have 1 hydraulic jack(it has a flat mount so I cant put it on the "teeth" of the factory slit on the car)
and the factory jack.
and 2 jack stands
HELP HELP
Old Jul 28, 2008 | 08:43 PM
terrasmak's Avatar
I use the outer mounting points for the under chassis brace just inboard and behind the mudflaps.
Old Jul 29, 2008 | 12:31 PM
_NIZMO_'s Avatar
_NIZMO_
wont the jack damage the teeth (red arrow)
Old Jul 29, 2008 | 12:35 PM
VO...'s Avatar
VO...
Administrator
It will. Mine are all jacked up and crushed anyway.
You could place the jack and stand under the "A frame" beam, that runs the length of the car on both sides. It sits about 10 inches inboard. BTW, I'm not sure if it's called an "A frame" beam. I'm sure someone will call me out on it, so I'm adding the disclaimer now....
Old Jul 29, 2008 | 01:06 PM
Skrilla's Avatar
Skrilla
There is a single jack point used to raise the entire front end of the car so that jack stands maybe used on the sides. It sits right behing the oil pan...I'll check it out when I get home so I can give you more detail
and 2 jack stands
HELP HELP
Old Jul 30, 2008 | 12:10 AM
Eric the Ricer's Avatar
Eric the Ricer
Have fun on the coilover install. It was a pain in da azz for meee.
Old Jul 30, 2008 | 04:52 AM
sbZenth's Avatar
sbZenth
I always use that metal plate in the center of the car. My sides are all crushed up from using the sides before i was smart enough to realize it.
Ill take a pic when i get home.
Which coilover set did you buy?
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
