Pulsating Rubbing Sound When Turning Left
Old Aug 14, 2008 | 06:13 PM
DukeEntDotCom's Avatar
DukeEntDotCom
blah
Default Pulsating Rubbing Sound When Turning Left
Today while on the parkway I noticed this sound. The faster I go, the more prominent it is. I only need to turn left slightly, and I hear this pulsating rubbing sound. It sounds similar to the tire sound if you drift over into the shoulder and drive over those grooves they put there to wake you up - but not that loud, and not constant. It pulsates on and off like vvvVVVVvvv vvvVVVVvvvv vvvVVVVvvv
I searched a whole bunch of threads and not sure anyone else described what I am experiencing.
This Sunday we changed my stock sways and endlinks at our shop to hotchkis sways and spl endlinks.
Old Aug 14, 2008 | 10:20 PM
terrasmak's Avatar
Wheel bearing ???
Old Aug 15, 2008 | 01:39 AM
r_seng's Avatar
r_seng
What wheel combo are you running on (specs?) Also what suspension (specs)?
Old Aug 15, 2008 | 04:46 AM
DukeEntDotCom
blah
Wheels:
G-Games Barracuda
(2) 19X10.5 5-114.3 22GMM
(2) 19X 9.5 5-114.3 22GMM
Tires:
Vredestein
(2) Size255/35ZR19
(2) Size275/35ZR19
I've had these on for about 5-6 weeks now.
Suspension:
Tein Basic Coilovers (not sure of the drop, as the suspension was already done before I purchased the car - but it's not really aggressive)
Old Aug 15, 2008 | 07:40 AM
j1234's Avatar
j1234
check your tires. the tires will make a similar noise when the have been worn irregularly. easiest thing to check is to take the wheel off the car and run your hand over the tire and if you feel bumps that is most likely your problem.
Old Aug 15, 2008 | 02:15 PM
DukeEntDotCom
blah
will do...thanks
Old Aug 15, 2008 | 03:21 PM
Mr350Z's Avatar
Mr350Z
Just a thought - If you feel anything in your steering and your're running headers, your headers could be rubbing against your steering rack.
Old Aug 15, 2008 | 04:41 PM
Ruthless18x's Avatar
Ruthless18x
Is any of your black plastic loose underneath? I had a similar issue when one of the wheel well guards.
Old Aug 16, 2008 | 06:37 AM
DukeEntDotCom
blah
I am not running headers...but when it happens the vibration could be felt in the steering wheel.
I did think about the black plastic pieces as well...something I am going to try and check out this weekend.
I brought it to a shop yesterday, and they couldn't figure out what it was. The mechanic said that he checked to make sure everything was tight...
Old Aug 16, 2008 | 12:43 PM
Changvi's Avatar
Changvi
Its either you are rubbing or your alignment is off.
Old Aug 16, 2008 | 07:41 PM
DukeEntDotCom
blah
Car pulls right...
I took it to Nissan some time back, and they wouldn't do my alignment due to the aftermarket suspension and such. That was before I even put the sways on...
A couple guys in my car club told me to get a corner balancing done after we did the sways. Maybe this will solve the issue.
Old Aug 19, 2008 | 05:10 AM
zzzya's Avatar
zzzya
I have the same issue, but when I turn right. If this sound does not happen when going straight, or very minor, or when turning the other direction, it is most likely the wheel bearing. After searching more for this topic I have found that numerous people have had to replace their wheel bearings. From what I have read I am going to order the parts and do this myself. The local nissan shop wanted to charge me $400 for parts and install. I think I can replace all 4 wheel bearings for that!!!!
Old Aug 20, 2008 | 11:33 AM
WTX350Z's Avatar
WTX350Z
Good ol fashioned way to check if it is wheel bearing:
1. jack wheel off ground, suspension unloaded usually easier.
2. Place one hand on the spring- (non dominant hand)
2.5 - make sure you can spin the wheel/tire w/o hitting your non dominant arm/hand
3. spin wheel with other hand. (dominant.) - may have to get it spinning pretty fast.
If you feel vibration its a wheel bearing which needs replacement.
Try both fronts, and compare. If one side you don't feel much of anything, except a minor vibration, and the other side feels like someone is tapping the spring your touching. then its bad. Its kinda hard to describe the feeling it will provide, but once you've felt it, you'll know it.
You can touch any part of the suspension but I've found the spring seems to resonate the vibration more than other parts, and its generally easy to touch.
I'd suggest doing this before throwing parts at your car.
On another note: rubbing feeling when turning automatically points to Tire rubbing, so look into that as well....esp with heavily modded suspensions.
Old Aug 20, 2008 | 11:40 AM
thekinn's Avatar
thekinn
Dumb question, but, did you try removing the wheel and putting it back on - then re-torquing the lugs? Just try it - I had a similar issue and the wheel looked fine, but apparently was not completely flush.
Old Aug 20, 2008 | 05:10 PM
350z_drifter's Avatar
350z_drifter
i have the same issue when turning left sound like it is rubbing
i have 19x9 w/26 offset with 245/35/19 and 19x10.5 w/22 offset with275/35/19 i have tanable 210 spring 1.2 front and 1.2 rear but only if i turn left it sound like it rubbs i wonder if the shock could be bad
Old Aug 21, 2008 | 08:16 PM
WTX350Z's Avatar
WTX350Z
no
Here's a quick way to look for the problem. jack car up...I used to do this with air jacks, so @ home its a little harder. but not impossible. jack front of car off ground (suspension must be compressed)...keep jacks far enough back where you can turn the wheel all the way to lock. then do that...look for the tire touching anything...if it makes it easier for you spin the tire, listen for sounds, and track them down.
If wheel/tire is rubbing, this should show you where.
If you jack the car up with suspension uncompressed (hanging) you can do my wheel bearing test, and also check for play in the front end (ball joints, tie rods).
Old Aug 25, 2008 | 03:40 PM
DukeEntDotCom
blah
Originally Posted by WTX350Z
no
When doing this, what is the best way for me to keep the suspension compressed while jacked up?
Old Aug 28, 2008 | 01:31 PM
DukeEntDotCom
blah
um
Old Feb 23, 2009 | 10:50 PM
yolkyolkyolk's Avatar
yolkyolkyolk
has anyone figured out what this problem was? I am getting the same vibrating noise when i turn the wheel just slightly to the right. I am on completely stock suspension and stock wheels btw.
Old Sep 22, 2009 | 12:42 PM
lope483's Avatar
lope483
i am experiencing the same thing. i just had an APS tuner ki installed. the shop said it was the header rubbing against the steering column. they said they shaved as much as they could while still being safe off the steering column brackets and used a prybar to move the 2 pieces apart. it worked for like a month but now its back.
