JIC coilover install help
Old Feb 15, 2004 | 04:44 PM
  #41
sdpearso's Avatar
sdpearso
Originally posted by woogemooge
dug up from the dead...
i'm looking into JICs for my car as well, and i can't find the definitive way of installing the rears. i'm worried about the noise...anyone finally solve this problem??
I had no problems by installing them as shown on their webpage. The rubber ring goes on the top and the adjustable purch on the bottom.
No noise, no loosness...
Old Feb 18, 2004 | 01:14 PM
  #42
MCopare's Avatar
MCopare
I am going to attempt to install my JIC's this weekend. Can anyone give me a step by step process to install these? Also the tools needed. Thanks a million.
Matt
Old Mar 19, 2005 | 06:23 AM
  #43
konspec's Avatar
konspec
i think there might be some confusion regaurding the linear and progress diameters. Does anyone have a definate measurement. Linear springs mount on bottom progressive on top.
Old Aug 12, 2005 | 03:48 PM
  #44
vaderzo6's Avatar
vaderzo6
sorry to bring this back but installed the rear suspension with perches on bottom and moddified the top cone rubber mount to accept the spring. ive had no rattles from this BUT what does rattle is the actual shock when i go over bumps and its really hoppy in back. basically the top of the shock mount rattles around is there a fix for this or am i going to have to live with it. also where are these directions for JIC's that would help a lot maybe i missed a bushing or something. thanks
Old Aug 12, 2005 | 04:11 PM
  #45
G352NV's Avatar
G352NV
Im selling my set for 1000.00 like new with 3k on them.
Old Aug 12, 2005 | 11:23 PM
  #46
vaderzo6's Avatar
vaderzo6
figured problem out, now i have no rattling at all smooth as hell and it handles noticeably different with full jic's and camber arms and traction rods. awesome, very time consuming install but worth it.
Old Aug 13, 2005 | 06:45 AM
  #47
John's Avatar
John
The pillow-ball mounts will rattle, and there's nothing you can do to remedy it. Have fun with these POS'. Oh, and hope yours don't start leaking soon... LOL
Old Aug 13, 2005 | 07:34 AM
  #48
konspec's Avatar
konspec
just got mine back, had both fronts revalved because of some serious leaking. As far as install of rear the guy form jic said progressive springs=perch on top, linear= perch on bottom. And if the rattling happens at low speed only its the pillow ball mounts. When you take your wheel of grab the shock body you'll feel a slight movement. That's just the design some people have had the top bolt tightened were the dampening adj is but, I could'nt get it any tighter at all.
Old Aug 13, 2005 | 07:23 PM
  #49
John's Avatar
John
Did they revalve your dampers on warranty without any question? I would hope it was free of charge since JIC dampers have such a documented history of prematurely leaking...
Old Aug 15, 2005 | 04:50 PM
  #50
konspec's Avatar
konspec
negetive i bought them off another member and they had 10k on them
Old Aug 16, 2005 | 09:10 PM
  #51
Z33@TOR's Avatar
Z33@TOR
how can you tell if there's a leaking?
Old Oct 22, 2005 | 07:07 AM
  #52
jkoc's Avatar
jkoc
wth?
jak's purple springs are FATTER than mine
my stock cone rubber piece is much fatter than my purple spring
Originally Posted by jak
I first had the perch at the bottom and they rattled like crazy. That is what JIC's web page shows. JIC told me to drill through the aluminum lower arm on the car into the perch and bolt them together. I thought they were nuts, the perch didn't even sit straight because of the spiral in the lower arm.
With the perch at the top no rattles, easier to adjust, and fits and sits the way Nissan engineers designed it to.
Here is a picture of the JIC spring with the stock rubber boot attached:
Jeff
