Tokico hp shocks... worth it?
Old Sep 5, 2008 | 07:15 PM
enuff4life's Avatar
enuff4life
Default Tokico hp shocks... worth it?
I'm getting Tanabe GF210 or eibach sportline Springs with Tokico hp(blue).
the shocks are only $250, so in my opinion, it is really cheap to replace for OEM. However, is it worth?
Moreover, I want same or little bit stiffer spring rate than stock 06+, but my choices(tanabe or eibach) are softer than 06 spring rate...
What would be good combination w/ tokico shocks?
Also, does Tokico hp blue and D-spec different in perfomance wise?
OR should I just grab a used set of buddy club for $800?
Old Sep 5, 2008 | 08:55 PM
THe Emperor's Avatar
THe Emperor
I wanna know the same thing. I've been wondering the same thing HP vs Blue. I have Sportlines just haven't installed them just.
Old Sep 6, 2008 | 05:24 AM
enuff4life's Avatar
enuff4life
i think, HP and blue are samething
just HP(blue) vs D-spec
Old Sep 6, 2008 | 05:33 AM
THe Emperor
^^^Yeah Blue vs D Spec.
Old Sep 6, 2008 | 07:57 AM
Ztalker's Avatar
Ztalker
i DIY installed Tokico D-spec since 04 to get rid of that stock suspension bounce. D-spec is designed to work well with the OEM springs. Never had any issues at all with those fully adjustable Tokicos.
Old Sep 6, 2008 | 01:48 PM
fart_canon's Avatar
fart_canon
Question
it is so funny! after spending the entire f****ing day today reading articles, reviews and member's set ups I decided to go with Tokiko D-spec and GF210. My only concern now is the SPC Rear Camber Arms; some say it is not needed and some say it is a must because of the 1.2 drop. I read Zs vary and it is determined whether you need these or not until you get alignment. If anyone with this same set up is reading can you tell me your experience?
Old Sep 6, 2008 | 02:02 PM
bimmertech's Avatar
bimmertech
i have the d-spec kit that have a 1.25" drop and i did not need the camber arms/toe bolts.
i do not run factory alignment settings, but i am able to achieve them if i were so inclined to ruin my handling
Old Sep 7, 2008 | 04:20 PM
enuff4life's Avatar
enuff4life
Does anyone know if they are different in performance wise except damping adjustability?
Old Sep 8, 2008 | 02:47 PM
enuff4life's Avatar
enuff4life
Even if I get D-spec, I will turn the damping setup to top(more stiffness). So I would rather save some money(hp is $220 cheaper than d-spec) for daming control....
So... are HP and D-spec are really different?
ablaine
Nov 29, 2016 10:13 AM
RiujinZero
Sep 25, 2015 01:19 PM
tubanoshop
Central California
Sep 16, 2015 08:03 AM
Suffolk350z
Sep 13, 2015 02:43 PM
