Toe arm advice
Old Sep 19, 2008 | 11:18 PM
wesismyhero's Avatar
wesismyhero
Default Toe arm advice
So Im getting ready to buy some true coilovers and get away from the OEM spring bucket set up. Any advice on which toe arms are the best?
Old Sep 20, 2008 | 07:06 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the ONLY correct way of doing it is replacing that entire oem arm.
Old Sep 20, 2008 | 02:06 PM
wesismyhero
But that part is basically just a replacement spring bucket with adjustment built in. I have seen several people just run a toe arm between there.
Old Sep 20, 2008 | 02:59 PM
Z1 Performance
Former Sponsor
I've seen people ride motorcycles in shorts, t shirts without helmets too, but doesn't mean I'd follow their lead
take a look at how the pros do it...follow their lead. Make sure you understand what you're getting yourself into with a true rear coilover
The 380RSC for example goes about it the correct way.
Old Sep 20, 2008 | 03:23 PM
wesismyhero
Andrew Hately, a Formula D drifter with a 350z, has true coilovers and is running a battle version toe arm there instead of a spring bucket. He just took out the bucket and ran the toe arm between the mounting points for the bucket. He has had no problems and says he likes it much better.
Old Sep 20, 2008 | 04:32 PM
Z1 Performance
Former Sponsor
yes I confused the two - I think Battleversion were the ones I was thinking of. I know one of the firms out there has a link made specifically for this purpose. The other thing you have to pay attention to are the bushings were the strut mounts to the hub
Old Sep 20, 2008 | 11:12 PM
wesismyhero
The battle version ones are supposed to be the best, but I wonder if the other toe arms are long enough to reach. Several people said just leave the bucket empty.
What is the problem with the bushing? I'd say it wears out from extra stress due to the springs.
liqalu04
Jan 2, 2022 12:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
