Is it okay to mix dot 3 and dot 4 brake fluid?
Old Sep 24, 2008 | 06:12 AM
kenempireex's Avatar
kenempireex
Default Is it okay to mix dot 3 and dot 4 brake fluid?
Is it okay to mix dot 3 OEM brake fuild with dot 4 ones? A shop just did a brake bleed for my car, but they refilled with dot 4 Endless brake fuild. They didn't flush the system. The mechanic said no problem, but apparently I found out that it will get a even lower boiling point than just used regular dot 3 fluid. What should I do now? Any help is appreicated, thanks.
Old Sep 24, 2008 | 08:04 AM
terrasmak's Avatar
Your perfectly fine, a normal full bleed actually flushes the system. It may be lowered up to 5 degrees , but considering you had Dot 3 in it before, your not racing the car at a national level where it will matter.
lapham3
Oct 7, 2022 03:15 PM
samansharif
Sep 25, 2015 12:31 PM
