Q on combining Hmax III's with Cusco sways
Old Oct 2, 2008 | 12:04 PM
Russ's Avatar
Russ
Default Q on combining Hmax III's with Cusco sways
I installed Cusco sways a while back, and they're fantastic, I love'em. So I'm thinking about taking the next step on the suspension and add coilovers (or a shocks/springs combo but prefer a coilover, I'm currently still running stock '03 shocks & springs). I'm sure the Nismo S-Tune suspension would be more than adequate for me, and the Hmax III's would probably be overkill but what the heck. It seems that for a little more cash, I can get the Hmax III's and have a wide range of adjustability compared to the S-Tune (which have no adjustability). Daily driver & street performance, looking to reduce the bounce on the freeway, lower the car a bit (1" or less) and further improve handling.
Spring rate wise, the Hmax III's seem to be a similar setup to the S-Tune. Both 9kg/mm (504 lbs/in) in the rear and fairly close in the front (S-Tune 8 kg/mm (448 lbs/in), Hmax III 9kg/mm (504 lbs/in)). The Cusco sway is also stiffer in the rear than the Nismo S-Tune sway so it seems like the Cusco rear sway might be a good combo with the slightly stiffer Hmax front springs. I have no idea how the dampening of the S-Tune shocks compares with the Hmax III's.
Before I do something really stupid, just wanted to see if anyone is running with the Hmax III coilovers combined with Cusco sways?
What are your thoughts on this combo?
hulkout
Apr 28, 2017 09:00 PM
RiujinZero
Sep 25, 2015 01:19 PM
Darkspy
Sep 7, 2015 09:09 PM
