help with eibach please?!?!
Old Aug 11, 2003 | 06:19 AM
nissfam's Avatar
nissfam
Default help with eibach please?!?!
I searched for a write up on how to install eibach pro kit springs but could not find anything on it. If someone has installed or knows how to do the rear springs I would appreciate any help.
Thanks in advance
Old Aug 11, 2003 | 08:39 AM
zwindsor's Avatar
zwindsor
Twisty addict
If you know how to do the front which is more complicated then the rear should be a piece of cake. Surprised your asking.
Loosen the lower link at both ends. Support it with a jack. Remove the front bolt and lower it down slowly. The spring will come right out. Make sure you install the new spring in the same position as the original. Jack it back up into position and tighten it all back up. Torque accordingly.
Old Aug 11, 2003 | 09:56 AM
nissfam's Avatar
nissfam
Cool, I just havent done that type of suspension before. I had a feeling thats what I needed to do. Where can I find those torque specs from? (front & rear)
Old Aug 11, 2003 | 10:03 AM
zwindsor's Avatar
zwindsor
Twisty addict
In the Service manual. PM me your email and I'll send the F/R sections.
Bodyboarder81
Nov 2, 2015 12:17 AM
seagrasser
Oct 11, 2015 03:27 PM
