Hotchkis Front Sway Bar Clunking Sound: Does this look right? (pics)
Old Nov 20, 2008 | 01:20 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Originally Posted by MikeyG
Do bad endlinks make a clunking noise on most bumps or only on very hard suspension compression like from a large bump or pothole? In other words does it take a lot of force to get them to bind up and make noise or does it happen all the time if they are bad?
it's actually most audible at very slow speeds over uneven pavement - at least thats where I first noticed mine going bye-bye
Old Nov 22, 2008 | 09:50 AM
PGT313's Avatar
PGT313
Installed the Powergrid endlinks yesterday (front and rear)
http://z1auto.com/prodmore.asp?model...ng&prodid=2886
You'll be happy to know that it solved all clunking issues, and i'm VERY happy with them.
Easy to install also, with detailed instructions.
THANKS ADAM!!!
(btw hatch struts work awesome also, damn strong!)
Old Nov 22, 2008 | 10:47 AM
Z1 Performance
Former Sponsor
good stuff Peter, enjoy and thanks again
Old Dec 8, 2008 | 12:37 PM
Stanky19's Avatar
Stanky19
Incase anyone is still having this issue, i have hotchkis sways on the soft middle hole up front and the middle hole in the rear, with powergrid endlinks all installed at the same time. I had no noise issues, and all of a sudden i am getting massive popping from both bars on uneven pavement at less than 40 mph, especially when going less than 10 mph. I have yet to test the grease (loosening endlink and rotating the bar) and check the underside of the car for anything loose, but upon last inspection (200 mi. ago) everything was good. I'll keep any findings posted when i dive into it tomorrow with a tranny flush. As a side note, does anyone know a good grease rather than the one hotchkis included?
Old Dec 8, 2008 | 12:40 PM
trodis's Avatar
trodis
http://www.redlineoil.com/products_c...ubCategoryID=8
Great stuff.
Old Oct 23, 2010 | 06:51 PM
Kuhan's Avatar
Kuhan
I started to hear this clunking sound from the front Hotchkis sway bar on slow speed as well. The only fix is to get aftermarket endlinks?
Old Jan 30, 2011 | 10:21 AM
karas..56's Avatar
karas..56
mine has start doing those noises from the rear after 2 months i got installed the hotchkis sway bar it's really annoying me and i keep the rear on full soft ..should i try to put some grease ?and where exactly i must put it? or i go back to oem sway bar at the rear ?..
Old Jan 30, 2011 | 04:03 PM
my04fairlady's Avatar
my04fairlady
Same thing happen to mine a Few times after not tightening the bolt off the endlink that goes through the bar all the way. They look like they are torqued correctly, but once you put a wrench on the bolt they are lose. I tighten mine to about 70 80 pounds. O ya Mine are stock endlinks.
Old Jan 31, 2011 | 07:09 PM
tyau's Avatar
tyau
Bad endlinks definitely cause that, but endlinks that are not tighten or adjusted properly also makes a clunking or popping noise.
Notice that endlinks have two nuts. The two nuts have to be tightened properly to clamp the sway bar to reduce noise. Any motion on the endlink should be within the spherical ball, not the endlink bolts.
Obadabot
Jun 18, 2023 11:31 PM
