SPC Rear Camber Arms Install HELP!
Old Nov 26, 2008 | 02:17 PM
JonnyB504's Avatar
JonnyB504
Default SPC Rear Camber Arms Install HELP!
I cant get the inside bolt off the OEM camber arm....any ideas? Do I have to drop down the sway bar or something? Please help...thanks!
Old Nov 26, 2008 | 02:54 PM
Beau's Avatar
Beau
Yes, you have to remove the bolts for the swaybar to make room to pull the bolt out. Both sides or it still won't move out of the way.
Old Nov 28, 2008 | 02:13 PM
SS728's Avatar
SS728
You have to figure out how to wiggle it out of there.
I had the same problem the first time (driver's side).
If you move the camber arm down while moving the bolt up, and vice versa, it should eventually slide out.
No need to remove the swaybar.
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
samansharif
Sep 25, 2015 12:31 PM
