Questions about: DIY 4w Brake pads+...
Old Dec 6, 2008 | 01:11 AM
dragonball d's Avatar
dragonball d
Default Questions about: DIY 4w Brake pads+...
rotors+brakelines+fluid bleeding
i did rotors+brake pads change for a 06 g35 before, but not the rear. what i heard from people there are some issues about z's rear brake, please tell me before i make any mistake. i m broke i have no money to pay that $150 brake changing+bleeding labor...
Thank you
i m new here this is my first post so i post this lovely leah pic
Old Dec 6, 2008 | 06:02 AM
Z04's Avatar
Z04
there are no issues with it if you know what you are doing. if you are switching rotors make sure you do not engage your emergency brake prior to removal. that would ensure you have a long and painful experience.
Old Dec 6, 2008 | 05:18 PM
Beau's Avatar
Beau
I can't speak for Brembo's, but the base model brakes have no tricks to them. Like Z04 said, just leave the parking brake off if only so you can turn it if you have to for some reason. Definitely if you are changing rotors. Have a deadblow hammer handy if you are changing rotors, they can be stubborn sometimes. My left rear was a major pain, the rest came off with no trouble.
Old Dec 6, 2008 | 06:02 PM
terrasmak's Avatar
post in the regional section , i bet someone will gladly help you out.
Old Dec 9, 2008 | 01:03 PM
quakerroatmeal's Avatar
quakerroatmeal
I recently tried to change out the rear rotors, but it was near impossible to get those sob out, is there a better method to take them out? I had to just leave em on and changed the fronts only. The fronts was a BREEZE, I used a longer bolt to go in the hole where the oem bolt went so they can't put your rear tires up front and it just pops the rotor out easily instead of trying to bang/pull it out. The rear's don't have it so I couldn't get it off. I even loosen the e-brake to make sure it was as loose as possible still no go.
Old Dec 9, 2008 | 01:10 PM
JasonZ-YA's Avatar
JasonZ-YA
^^ what we did wrong was you had the ebrake engaged before we started......live and learn.......
but you didnt need to change your rears anyway.....your rears were fine......your fronts were the ones that were F-up...
-j
Old Dec 9, 2008 | 02:12 PM
quakerroatmeal
We did disengaged them and they still would not go anywhere. Yeah I know we didn't need to that wasn't the point though. We had them disengaged and you even loosen the engagement point didn't you?
Old Dec 9, 2008 | 10:41 PM
dragonball d
thank you
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
Vigman
Nov 17, 2015 04:34 AM
LunchBox20
Oct 20, 2015 10:22 PM
