how to test if shocks are damaged
on
A while back, i installed S.Tech springs on my car. The font driver side started making noise. Everytime i would go over a bump, it would make a thud.
Now... i dont know if this was due to a wrong installation of the spring, or the shock going back. Is there a way i can get my shock tested ? I want to sell my stock shocks except i dont want to sell it before making sure it works.
thanks.
thanks.
TBH, I wouldn't trust them. They're probably going to take a quick look at your suspension then (depending on how old the car is) say to you that they need to get replaced. Or at the very least say that they're close to being done and would recommend changing them as soon as you can.
on
How do you know it's the shock? Could be a loose suspension piece.
But to test the shock specifically, you probably need to at the very least inspect it for leakage. If you still suspect it, you'll have to take it out and compress it (if it's shot, it will compress way too easy)
![Smilie](https://my350z.com/forum/images/smilies/smile.gif)
on
thanks guys. I will test it. I know there is no oil on it, so thats not the problem. Jeff, as you have said, i know it probably was a suspension piece that i messed up on the install, but i cant sell the shocks based on a guess. I need to be sure.
thanks for the suggestions.
![](https://my350z.com/forum/images/ranks/premier.gif)
![](https://my350z.com/forum/images/ranks/moderator.gif)
Lowered springs on stock shocks, they're trashed.
Just a note: Unlike softer sprung cars, my Z didn't get lazy and "floaty" like my old 67 chevelle with bad shocks. No, the Z started to "jiggle". Most obvious just after coming to a dead stop.
on
My stock shocks lasted less than a year after RS-R ti2000 springs. (Only .6" drop and just a hair stiffer than stock.)
Just a note: Unlike softer sprung cars, my Z didn't get lazy and "floaty" like my old 67 chevelle with bad shocks. No, the Z started to jiggle. Most obvious after coming to a dead stop.
on
Why they make shock dynos for people what want to know exact parameters.
http://www.shockdyno.com/
Do it yourself construction:
http://www.circletrack.com/howto/828...yno/index.html
on
Or just assume that the shocks are worthless by 4 years or 60,000 miles........historically this has been the case with Nissan since my 1985 300z, thru 88 Pathfinder, and 90 Q45 and 94 Q45.......................I've replaced 10 sets of shocks on my Nissans/Inf.
After removal [none leaked] but none would self expand and a child could compress and expand them without effort.
Being mounted inside the springs fools you until you disassemble more modern designs make it easier to just disco the bottom to test on car.
