Using impact tool o assemble shocks
Old Dec 23, 2008 | 05:01 AM
MR RIZK's Avatar
MR RIZK
Default Using impact tool to assemble top hat on shocks
Quick question, Picked up a set of new suspension and the doco states not to use a impact gun to do up the top nuts where the hat goes as it may damage the shock.
I have always use an air tool to do up the top nuts as if you try to do it by hand the inside piston spins.
Anyone got any good tips.
Old Dec 23, 2008 | 08:23 AM
Chebosto's Avatar
Chebosto
are you doing it the "ghetto" way by shooting the top bolt into a trash can and catching the top mount as the spring uncompresses? or using a spring compressor?
typically on the top of the piston, there is a notch that you can grab a hold of using an adjustable wrench, and using an open wrench get the.. 12mm (or was it 14mm) bolt off so the piston doesn't spin.
time consuming yes, but you avoid any issues of over torquing the nut and stripping the top of the piston thread if u use air tools..
Old Dec 23, 2008 | 09:48 AM
guitman32's Avatar
guitman32
Tip: Loosen the top nut while still mounted on the car using and offset wrench (Edit: BUT DON'T REMOVE). This is the best way I have found to avoid damage to the shock piston assembly. Once it's off the car and you need to remove the hat it will be pre-loosened and easy to remove. Another tip...when you're done have need to re-tighten the nut, get it as tight as you can while off the car (probably not tight enough), mount it on the car, use a floor jack to compress the assembly a bit, then tighten while on the car (just like removing it).
The key to all this is an offset wrench to allow you access to the nut while they are on the car.
Old Dec 23, 2008 | 01:15 PM
MR RIZK's Avatar
MR RIZK
depends on the length of spring but I normally use a spring compressor so I do not stress out the last few threads. On a coil over I normally loosen the bottom spring plate so the spring loosens first.
The bilstein PSS10 that I have bought have a section at the top where there is no thread that i could grab on (will need to use a vice grip as there is no flats for a spanner) but I believe when I will mount the factory top hat to the shock I will not be able to reach this section.
Thanks for the tips
Old Jan 8, 2009 | 09:34 PM
MR RIZK's Avatar
MR RIZK
Just an update. You cannot really use a impact tool to assemble the shocks because the length of the socket to reach the nut near the top hat will need to be too deep. A box wrench is the best option.
When you take off the adjuster dial at the top of the strut there is a flat/notch underneath that you can use to allow you to tighten the top nuts.
Thanks for ideas.
Old Jan 9, 2009 | 01:18 PM
Lawn Dart's Avatar
Lawn Dart
Use an offset wrench to turn the nut and a wrench or Vise Grips on the center bolt.
Old Jan 9, 2009 | 07:46 PM
MR RIZK's Avatar
MR RIZK
I need to buy a set of those.. My offsets were not offset as much as those ones..
Old Jan 9, 2009 | 07:50 PM
surfcity40's Avatar
surfcity40
don't listen to chebosto...he's an SBC guy...He eats salad off his deck lid (and is WAY over invested in star wars).
Rowlett
Misc.
Oct 2, 2015 10:38 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
