Has GT SPEC revised their rear lateral bars yet for singles?
Old Jan 19, 2009 | 09:01 PM
got556's Avatar
got556
Default Has GT SPEC revised their rear lateral bars yet for singles?
I know this was a problem for anyone w/out a TD 3" setup and I was hoping by now that GT SPEC has revised their rear lateral arm bar to work w/ singles (namely the Greddy Ti-C single exit) (for a 350Z btw).
Secondly, I've got SPC rear camber arms and toe bolts. By taking off the nuts for the bolts on the camber arms and the toe bolt nuts (as you have to do for the GT SPEC) rear bars, will this affect my alignment?
Thanks.
Old Jan 19, 2009 | 10:14 PM
Chebosto's Avatar
Chebosto
Thanks.
if you keep the arms same length, and the toe bolts same angle, as they came out (i.e. same direction in which the oblong washer comes out from) you should be ok.
Old Jan 19, 2009 | 10:17 PM
got556's Avatar
got556
Thanks! Seriously...I've taken my bolts out a few times for springs, then CO's, then camber arms....so I know how easy it is to mess up the alignment by just ever so slightly moving one of the shims. I'll just go slow...take a sharpie and mark everything on the ships and on the suspension parts to line up and should be GTG, it sounds like.
Now if I can get the first question answered lol.
EnjukuRacing
Sep 30, 2015 06:55 AM
