Adjusting Coilover KW V2/V3
Old Jan 28, 2009 | 04:02 PM
AznSky's Avatar
AznSky
wow that's really important info. Thanks for doing the extra work gsedan35. I'll be sure to contact u before deciding on my suspension setup!
Old Jan 29, 2009 | 03:38 PM
OCG35's Avatar
OCG35
So the adjustment for these is at the top of the strut?... I asked a vendor that is selling them how they are adjusted and he said the rears are adjusted at the bottom (accessible between wheel spokes?)
I have D-Specs now and had to run a cable up the back of rear seat (sedan) in order to adjust… if these are adjusted front he top, it looks like sedans are out of luck?
Old Jan 29, 2009 | 03:46 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
whomever you spoke to is mistaken
Old Jan 29, 2009 | 03:54 PM
Alang35's Avatar
Alang35
yep, i have these and its at the top i have a g coupe... i would rather not drill holes in my cars chasis.... but it looks like theres no choice! i heard the bilstein coilovers have adjustment at the bottom. hks might also have it at the bottom too
Old Jan 29, 2009 | 04:33 PM
OCG35's Avatar
OCG35
glad I found this out... thanks for the verification.
Old Jan 29, 2009 | 05:48 PM
zettahertz's Avatar
zettahertz
hmm, thought the pics clearly showed that it's on the top haha. i just added a statement in bold to further clarify it. I'm planning to install it this weekend, bet it's gonna take me the whole day to do all 4 sides + rear camber and toe bolt (and drill in the rear to access the adjustment)... I gotta say, I actually dun really mind having to drill a hole there. I think removing a piece of plastic to adjust it beats having to crawl under the car.
Old Jan 31, 2009 | 05:35 PM
zettahertz's Avatar
zettahertz
ok, just got the OEM fronts out and put in the passenger side. taking out the OEM fronts are a *****! had to push down on the rotor and pull up on the strut at the same time and try to get enough space for it to come out.
And I was stuck for a while trying to figure out how to tighten the top locknut on the coilovers. the whole shaft on the strut turns when u try to tighten the nut. Had to find a piece of rubber and use a vice clamp on the shaft while attempting to tighten the bolt... also quite a ***** to do by yourself. can't even get the torque wrench to click b4 it starts slipping though, hope it's tight enough.
Old Apr 22, 2011 | 12:38 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
Does anyone have a better suggestion than this rubber method?
Old Apr 22, 2011 | 01:50 PM
LaoSiFu's Avatar
LaoSiFu
I use the strap wrench. Much safer and does not damage the piston.
~Robert
Old Apr 22, 2011 | 01:53 PM
3hree5ive0ero
Retired Admin
Cool. I have one of those and was just looking at it, too.
So for those who have these coilovers, are you guys just going by the rebound settings Gsedan35 recommended or some other setting?
Old Apr 22, 2011 | 02:07 PM
LaoSiFu's Avatar
LaoSiFu
Base off KW recommended setting, I am running two clicks stiffer on both front and rear. I don't think I saw what did GSedan35 recommended. What did he say if you happen to have that information.
~Robert
Old Apr 22, 2011 | 02:47 PM
3hree5ive0ero
Retired Admin
A different member posted his recommendation:
Thanks to GSedan35 for the shock dyno. He has determined that the best set up for the V2s are 9 clicks (1.5 turns) from softest for the front, and 6 clicks (1 turn) from softest for the rear. And stated that running it at too stiff is pretty stressful on the suspension, perhaps he can put more detail in the explanation. And he'll be receiving the dyno data from the shop owner that ran the dyno.
He never did end up posting the shock dynos.
Old Apr 22, 2011 | 11:11 PM
LaoSiFu's Avatar
LaoSiFu
I should consider a dyno one day and try to figure what is a good area to play with. One thing I do hate about the V3 is playing with both top and bottom adjustment. Such a PITA to adjust in my opinion.
Old Apr 22, 2011 | 11:56 PM
3hree5ive0ero
Retired Admin
It may be a PITA, but I actually like that you can fine tune it to your liking or needs.
Do you have links on how to properly interpret shock dynos or any other pertinent information? I have one that I'll read when I have some free time next week.
Stevo Z
Oct 3, 2015 09:14 PM
