Help! Wheel hub wobbles
Old May 19, 2021 | 06:40 PM
terrasmak's Avatar
Originally Posted by thekinn
I'm having a similar issue. I just had a shop separate the old bearing and hub, press on a new bearing the the existing hub, and I have the exact same wobble. Everything torqued to spec (hub/bearing assembly to car, axle nut, lug nuts). Terribly frustrating to get the car apart and all put back together and find that I didn't fix anything.
Guess it's time to source both a hub and bearing and try again.. plus get my ARP studs swapped over.
every rear hub I smoked, also took the hub with it
Old May 30, 2021 | 05:42 PM
thekinn's Avatar
thekinn
New hub and bearing fixed it.
Obadabot
Jun 18, 2023 11:31 PM
