CANNOT get bolts off endlinks...
Old Jan 28, 2009 | 01:44 PM
SimC33's Avatar
SimC33
Default CANNOT get bolts off endlinks...
I have tried using PB buster, WD40...i sprayed nearly the whole can on the bolts...WTF do I do now? the damn thing is close to being stripped. I have used the 14mm hex bolt and different sized torque wrenches...NOT WORKING...please help, I'm quite pissed.
Old Jan 28, 2009 | 02:01 PM
Chebosto's Avatar
Chebosto
worse comes to worse-
remove the bar completely, by removing the other side of the endlinks, and the two clamps that hold the sway bar to the car..
if it is already stripped, you can think about cutting the nut off and / or replacing the entire endlink unit after you slice the bolt off.. i've had good experiences with liquid wrnech, you have to squeeze inbetween the threads and let it sit for a while for the liquid to work its way in..
Old Jan 28, 2009 | 02:12 PM
RandomHer0's Avatar
RandomHer0
^^ This is exactly what I had to do with mine. I had to take the the rear completely off and cut the bolts off.
What a pain...
Old Jan 28, 2009 | 03:02 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
Take a torch to them to heat them up. I'd suggest getting as much of the WD40 off as possible because of that whole flammability thing!
Old Jan 28, 2009 | 07:17 PM
SimC33's Avatar
SimC33
So if I do resort to cutting the bolt off (which I hope I don't) where would I go to get another bolt like it at? Also, what is its size? I know its a 14mm but are there any other sizes to know
Old Jan 28, 2009 | 07:36 PM
JETPILOT's Avatar
JETPILOT
You should have used "PB BLASTER".... Not PB Buster. That's where you went wrong. Don't accept cheap immitations.
Seriously..... Impact wrench!
Old Jan 28, 2009 | 07:38 PM
SimC33's Avatar
SimC33
My bad it is PB blaster...its w/e is at advanced auto parts next to the WD40...
Old Jan 28, 2009 | 08:02 PM
terrasmak's Avatar
Had to cut a set off my car, sucked.
Old Jan 28, 2009 | 08:56 PM
SimC33's Avatar
SimC33
Where did you go to replace the bolts that you cut?
Old Jan 29, 2009 | 07:04 AM
terrasmak's Avatar
Just bought new endlinks from the dealer, they are cheap. Make sure you order the nut with the endlink, they do not come together.
Old Jan 29, 2009 | 10:25 AM
blasian's Avatar
blasian
Damn Joey, you need me to donate some muscle to you
If you don't have them installed this weekend, I could probably help.
Old Jan 29, 2009 | 10:32 AM
SimC33's Avatar
SimC33
Thanks for the awesome reply there greg, but I'm sure I got the muscle category covered though. If you need help opening a jar again, be sure and let me know.
Old Jan 29, 2009 | 10:33 AM
SimC33's Avatar
SimC33
Ok sounds good, thank you
Old Jan 29, 2009 | 10:34 AM
blasian's Avatar
blasian
As long as you're still makin my sammiches bish
Old Jan 29, 2009 | 10:36 AM
SimC33's Avatar
SimC33
Well all I got is peanut butter in a screw top and jelly in a screw top...so you have double the duty...
ANYWAYS: Thanks for the reply guys, if I can't get the bolt off my next try, im breaking the bish off.
Old Jan 29, 2009 | 10:37 AM
blasian's Avatar
blasian
You may want to order stock endlinks before you do that. I think I threw mine away
AbrasiveRaysive
Sep 20, 2021 02:29 PM
wanderingstuden
Jan 28, 2016 07:03 PM
