Rear traction (Toe) Arms - Install?
Old Feb 26, 2009 | 05:59 AM
josesantigo57's Avatar
josesantigo57
Default Rear traction (Toe) Arms - Install?
I got the Kinetix rear traction (toe) arms, and i have problems installing them. There is a bolt that goes into the car behind the fender which is very hard to reach and its nut is even harder to reach.
Does anyone have a DIY or install guide or any info that could help me install this? Thanks.
Old Feb 26, 2009 | 08:51 AM
redlude97's Avatar
redlude97
you should just not install them at all and purchase spc toe bolts
Old Feb 26, 2009 | 02:08 PM
josesantigo57
Thanks, anyone else?
Old Feb 26, 2009 | 03:33 PM
350z_Gio's Avatar
350z_Gio
yeah i would just get the spc toe bolt.
Old Feb 26, 2009 | 05:39 PM
josesantigo57
Wow.
Old Feb 28, 2009 | 04:41 PM
josesantigo57
So i finally got them installed, turns out the nut for the toe arms does not come out, just the bolt. It takes some time, but its not as complicated as i first saw it.
The kinetix arms are A+ quality, they even come with polyurethane bushings, glad i got them installed.
Old Mar 22, 2012 | 11:20 AM
Ginevan's Avatar
Ginevan
I know I"m bumping a 2 year old thread, but Jose, how did you get the cone shaped bolt out? I've got my arms out, but that damn bolt doesn't want to come out. And I'm using a 24" breaker bar and an IR gun.
Old Mar 22, 2012 | 11:57 AM
terrasmak's Avatar
The bolt came right off mine, and btw those arms are not for adjusting toe, and will cause problems if you do.
Old May 10, 2015 | 06:31 PM
taywan's Avatar
taywan
Old thread but wanted to ask about the benifits on installing these when I already have the following :
Spc toe bolts
kinetix rear camber arms
curious if it helps w alignment and tire wear more? And wheel hop ive heard as well.
Thanks
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
samansharif
Sep 25, 2015 12:31 PM
