Need advice
Got into a scuffle with a wall!
Spun the car on an entrance ramp and hit the rear drivers side corner whilst going backwards. I need to get them back in spec or at least closer together. You can actually see the difference in angle between the two rears. Any suggestions?
My suggestion is to do a thorough inspection of all the suspension components before you start throwing stuff at it. Depending on where and how you hit, you could have bent a radius rod or other component. The only way to do this is to take the time to get under there and look for a bent part that should should be straight, etc.
liqalu04
Jan 2, 2022 12:58 PM
user 62082028
Southern California
Jul 28, 2017 11:47 AM
