eiback prokit VS tanabe GF210
Old Mar 3, 2009 | 01:20 AM
tw8715's Avatar
tw8715
Default eiback prokit VS tanabe GF210
soo the eibach prokit give a drop of 1" all around
VS
tanabe giving the drop of 1"front and 1.2" rear.
could you guys be of great help and point me in the right way?
and NO thanks no coil overs at this time haha~
i would like a nice even drop.. not a raked look.
my friend lowerd his TSX and his rear is lower then the front.. looks pretty bad to me.
but right now as of stock.. the rear is higher then the front.. so would the tanabe GF210 put the car at a even stance?
or should i just go for the eibach prokit and just lower it 1" all around? would it make the rear just a little higher then the front?
thanks
Old Mar 3, 2009 | 01:50 AM
tw8715's Avatar
tw8715
basically i want a nice clean drop, without the rear looking like it lower then the front.
but seems like in the pics.. the tanabe looks even and the eibachs looks lower in the rear..
when the specs arnt suppose to.
Old Mar 3, 2009 | 05:46 AM
ROM350Z's Avatar
ROM350Z
I would go with the eibach sportlines if i were you. Its a pretty low drop but i havent scraped anywhere with this drop so far and i've driven on these springs for around 1000 miles now. For now the ride quality remained the same(will probably go bad when shocks blow). It gives the car a nice even drop. The prokit lowers the car nicely but the rear stays up a tad. The sporlines give it that nice even drop.
Old Mar 3, 2009 | 03:07 PM
tw8715's Avatar
tw8715
thanks for the reply! even drop is what i am looking for.
but not so low as the sportline~
got a lip kit + steep drive way =
so sport line is out of the quetion.
anyone else?
thanks!
Old Mar 3, 2009 | 03:52 PM
jdavis169's Avatar
jdavis169
Are you lowered on stock or aftermarket wheels? Post some pics.
Old Mar 3, 2009 | 04:57 PM
Stogge's Avatar
Stogge
I just installed my Gf210's last weekend and I think your concerns are not warranted... The drop in the Rear on the GF210's is only 0.2 " more than the pro kit... Considering that that the "z" rear starts pretty high, it still looks like the same raked look to me, rear end is still higher than the front end, just by .2" less than before...
I took a pic today, let me upload it...
Old Mar 3, 2009 | 04:59 PM
jimpactmfsc's Avatar
jimpactmfsc
the tanabe gf210s settle very low,about as low if not lower than sportlines from what ive seen...GENERALLY if your going with those you for sure should buy a rear camber kit,u might possibly need a frontone down the line as well. eibach pro kit is very street user friendly,its what im getting installed soon.
Old Mar 3, 2009 | 05:00 PM
jduet's Avatar
jduet
Originally Posted by Stogge
I just installed my Gf210's last weekend and I think your concerns are not warranted... The drop in the Rear on the GF210's is only 0.2 "... Considering that that the "z" rear starts pretty high, it still looks like the same raked look to me, rear end is still higher than the front end, just by .2" less than before...
I thought it was 1.2"
Stogge's Avatar
Stogge
Sorry, the pic I took is from a horrible angle, you can't see what you need to... I took it from a bad side angle, there are many other pics floating around here, search "gf210" in the suspension forum...
Good Luck with your Decision!
Old Mar 3, 2009 | 05:02 PM
Stogge's Avatar
Stogge
Hhahahah, yeah oops, my mind was tripping over itself... Good Correction!
Old Mar 3, 2009 | 07:08 PM
tw8715's Avatar
tw8715
hmmm so are you guys saying the the tanabes are lower in the rear then the front?
and eibach is even?
Old Mar 3, 2009 | 07:14 PM
TheOtherRob's Avatar
TheOtherRob
The pro kit is a nice drop. You cant go wrong with either.
Here is a example of my friends car with the pro kit.
Old Mar 3, 2009 | 07:20 PM
TRYNALIVEPRO's Avatar
TRYNALIVEPRO
^any more shots?? different angles
TheOtherRob
Old Mar 3, 2009 | 07:23 PM
tw8715's Avatar
tw8715
thanks alot! looks good!
im just dont want the rear's being lower then the front!
seems like alot of the eibachs come out to be like that.
but when i see the tanabe pictures.. it dosnt look like that~
BUT the tanabe is suppose to be lower by .2 in the rear over the eibachs.
HMMMMMMMMMMMM damn it! cant make up my mind~ haha
Old Mar 3, 2009 | 08:19 PM
samjcg's Avatar
samjcg
^Eibach seems to be consistent on their drop, however gf210 always isn't(from what i am seeing this whole time). GF210 and Eibach Prokit both are great choice. just go with whatever is cheaper and has better condition.
Old Mar 3, 2009 | 10:29 PM
quakerroatmeal's Avatar
quakerroatmeal
GF210 is no where near as low as the sportlines.
But I have Tanabe NF210 it's pretty even, the rear is barely higher then the front, which is how I like it.
Old Mar 4, 2009 | 12:14 AM
tw8715's Avatar
tw8715
that is how i like it too!
i wonder if the gf210 are like that too.. hmmmmmmmmmmmmm
Old Mar 4, 2009 | 04:07 AM
cheshirecat79's Avatar
cheshirecat79
You can always cut the rear spring mount to make it even regardless of what springs you buy.
Old Mar 4, 2009 | 07:04 AM
TheOtherRob
Doesn't the NF210 and sportlines create the same drop? 1.2 all around
