OEM brake pads vs aftermarket pads?
Old Mar 13, 2009 | 05:25 PM
Diesel350's Avatar
Diesel350
Default OEM brake pads vs aftermarket pads?
So after reading and reading about brake pads on this site I still cannot decide what pads to go with. I am thinking of just sticking with OEM since they do provide enough bite for what I need since i don't track ever. What do you guys think? Should I go with an aftermarket pad or just stick to OEM since it's just a daily and I never track it?
Old Mar 13, 2009 | 05:43 PM
Chromex319's Avatar
Chromex319
If you can afford aftermarket then do it. Better braking means you'll be a little safer right? Peace of mind goes a long way. Plus they'll look better than stock. Do it. You know you want to.
Old Mar 13, 2009 | 05:49 PM
WXSigns's Avatar
WXSigns
Vendor - Former Vendor
Yeah, after market brake pads look better than stock...lol
Old Mar 13, 2009 | 07:10 PM
singh's Avatar
singh
_______________
wow that's just sad..
Old Mar 13, 2009 | 07:12 PM
bballgms's Avatar
bballgms
on this topic arent there nismo brake pads available for even non-brembo brakes are those better than the oem?
Old Mar 13, 2009 | 07:24 PM
Chromex319's Avatar
Chromex319
I don't get it. What's wrong with that statement?
Old Mar 13, 2009 | 07:25 PM
Chromex319's Avatar
Chromex319
OOOOOOoooooooooooooooooooooh!!!!!!! For some reason I was thinking he wanted to upgrade to big brakes. Long day man. Sorry.
Old Mar 13, 2009 | 08:03 PM
OEM pads offer good performance: wet and dry. What I don't like is the excessive dust. There are suitable alternatives.
Old Mar 13, 2009 | 08:15 PM
zettahertz's Avatar
zettahertz
i don't get how aftermarket pads look better than stock.
edit: nvm,didn't see your statement retract.
Old Mar 13, 2009 | 08:18 PM
kyx4n's Avatar
kyx4n
^ lol he already admitted that he misread and thought it said big brakes
Old Mar 13, 2009 | 08:23 PM
Chromex319's Avatar
Chromex319
doih! Imagine if I hadn't followed up? My flame suit is no where near me right now.
Old Mar 13, 2009 | 08:39 PM
$LiK RiK's Avatar
$LiK RiK
go with the oem pads if not racing on a track or no power upgrades.I've worked in a few used car dealers and had customers come back an complain about aftermarket pads making noise.We changed back to oem pads and never seen them again.
Old Mar 14, 2009 | 07:16 AM
Wheelman's Avatar
Wheelman
The OE pads are priced reasonably, so if you like them I'd just stick with them. Any change in pad compound is going to be a trade-off in some form of pad wear speed, cold or hot braking performance, noise, dusting, rotor wear, etc. The OE ones did the job just fine for me so that's what I stayed with. Considered going with some Project-Mu pads but didn't think they'd be worth a slight increase in performance for double the price for normal street driving.
Old Mar 15, 2009 | 07:27 PM
bblaze1874's Avatar
bblaze1874
I put on aftermarket pads just to cut down on the brake dust....was a great choice
Old Mar 15, 2009 | 07:34 PM
SniperHunter's Avatar
SniperHunter
06 brake pads don't dust much at all. And because 06 brakes are bigger and beefier than the 03-05 brakes, you'll be just great sticking to OEM pads. Aftermarket pads dust more, and can sound like **** many times (usually because they're a rougher compound than OEM).
Old Mar 15, 2009 | 08:05 PM
quakerroatmeal's Avatar
quakerroatmeal
Are there any aftermarket pads, with just as good/better initial bite, and has good low dust?
I'd stay with OEM if you like it, but dusts a lot.
If you go with aftermarket most of the time they will not have a good initial bite.
Old Mar 16, 2009 | 01:10 AM
ThE_JacO's Avatar
ThE_JacO
Aftermarket often don't have a good initial bite because they tend to be geared towards working at higher temperatures and taking the punishment of carved grooves keeping them lively.
It's all a matter of what type of pad you buy rather than aftermarket vs oem in my experience.
If you buy a cold soft pad you'll normally get a much better street/daily driver experience, at the expense of more dusting and shorter life (which isn't a big deal at all if you clean your wheels often regardless).
OEM in the category of a Z tend to do well at the things that the performance unconcerned driver gives a damn about, low dusting, reduced noise, and ok cold response. Change anything and you have to trade off something else.
If all you do is normal street driving and you don't want to deal with dust, it'll be hard to beat OEM, you could find equivalent or only very slightly better at best. But if you want that from your pads, then you're the intended consumers for those and there's nothing wrong getting them on again
If you don't care about dusting then most cold pads will do better.
If you want an upgrade that compromises nothing and is worth doing brake lines are a good shot IMO, the stock ones are crappy and as squishy as it gets.
Old Mar 16, 2009 | 06:34 AM
zerafian's Avatar
zerafian
Aftermarkets last longer, make less noise, create less dust, and are cheaper...OEM pads are over priced and are crap. I'v obviously had nothing but bad experiences with OEM pads compared to aftermarket.
Old Mar 16, 2009 | 06:42 AM
terrasmak's Avatar
EBC green and call it a day. What does the dealer charge?? If they are more $$ than the EBC's i know what i would get.
Old Mar 16, 2009 | 09:08 AM
Diesel350's Avatar
Diesel350
Front and Rear dealer is charging $138 but I get a 20% discount for being a club member so it would be $110 for the OEM pads for me. How much do the EBC's go for?
