SPC front kit install question
Old Mar 19, 2011 | 08:11 PM
maximariceboi's Avatar
maximariceboi
Ah ok thanks. Who makes the shim kit?
Old Mar 19, 2011 | 08:23 PM
gyotar's Avatar
gyotar
There's no real brand I guess. Any serious automotive or heavy machinery supply store should have shim sheets in various thicknesses. Get the thinnest shim you can so you have more control over spacing.
Old Mar 19, 2011 | 08:26 PM
gyotar's Avatar
gyotar
And by the way, after you install the shims and put it back together, you'll have to drive for about a minute before the lights go out so don't assume the gap isn't right until after a couple minutes of driving around.
Old Mar 19, 2011 | 09:20 PM
maximariceboi
Wow more work than I expected. I couldn't even get the alignment done yet and this is my daily driver to work. I guess I'll look into this in the morning and try the shims first since I have nothing else. Thanks for your advice.
Old Mar 19, 2011 | 09:23 PM
maximariceboi
By the way... I'm only lowered an inch so should I be using shims? I didn't touch the abs sensor or removing the hub. Please confirm too thanks again.
Old Mar 20, 2011 | 06:52 AM
gyotar's Avatar
gyotar
If you didn't install the spacers which require the hub to come off and change geometry then I don't think you needed to use the abs sensor bracket meaning the gap should be fine. If you installed the tapered metal spacer to give yourself more positive camber adjustment then you've changed how the hub and sensor sit in relation to each other.
Old Mar 20, 2011 | 07:30 AM
maximariceboi
Oh ok. Yea I didn't install any spacers but the abs keeps kicking on once in awhile when I was driving around after the install. However I did notice a lot if negative Camber and negative toe in one of the rear wheels. Would that cause the abs to kick in?
Also I'm on greddy coilovers if that makes any difference. Thanks
Old Mar 20, 2011 | 07:55 AM
gyotar's Avatar
gyotar
LOL if the lights are only on randomly then go get an alignment!
Old Mar 20, 2011 | 07:58 AM
maximariceboi
Lol that's what said earlier that I need an alignment haha so you don't think those shims are needed? Or can't tell once the alignment is done?
Nobody is open Sunday which sucks lol
Old Mar 20, 2011 | 08:27 AM
gyotar's Avatar
gyotar
My mistake I thought we were talking about shims for the Abs sensors which would throw those codes. I think you're talking about the shims for the actual alignment LOL. Disregard Ahaha.
Old Mar 20, 2011 | 08:37 AM
maximariceboi
Lol I'm confused haha. Let me recap...
Installed Greddy coilovers along with spc a arms and spl rear camber arms. The spc a arms I did not use the shim kit that came with arms because I'm only lowered 1". so I did not touch the abs sensor or removed the hub. I def need an alignment done since I have alot of neg camber in the front and neg toe on 1 of the rear wheels.
Since the install... I was driving around and a minute later the abs and vdc off light comes on and abs kicks in. Is this just an alignment issue? Or does the shim kit (metal brackets for hub and abs sensor need to be installed?
Ah typing on my iPhone is annoying lol. Thanks
Old Mar 20, 2011 | 08:47 AM
gyotar's Avatar
gyotar
It shouldn't be required for your drop.
Old Mar 20, 2011 | 08:51 AM
maximariceboi
Yea ok thx so it's probably an alignment issue I hope.
Old Mar 21, 2011 | 06:51 PM
maximariceboi
fixed the issue. thanks.
Old May 16, 2011 | 03:12 PM
Shizzmaster2k's Avatar
Shizzmaster2k
My Z also has the ABS,VDC,Brake lights constantly on and I get the occasional noise all coming from the right side of the vehicle. It went off for a week and then came back on and this is after I got an alignment as well. I'm running SPC Front A-Arms and Tein Flex Coilovers. What size shim did you use for the ABS sensors and how far should the gap be between the sensor and the hub (Correct me if I'm wrong)?
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
ZXoltan
Brakes
19
Nov 25, 2015 04:21 AM
bcoffee20
Nov 19, 2015 06:39 PM
Bodyboarder81
Nov 2, 2015 12:17 AM
CJs_Z33
Sep 18, 2015 12:06 PM
