Brake pad install question
on
ill be changing my brembo pads and want to know if I apply the antisqueal compound between the shim and pad, on top shim, or both areas?
Thanks.
Thanks.
on
You might get some replies if you put your threads in the correct forums.
https://my350z.com/forum/brakes-and-suspension-399/
https://my350z.com/forum/maintenance-and-repair-53/
on
Me being from Louisiana and all could possible assist you in the installation of the brake pads. As for where to apply the grease I would put it on the back of the pads, not the side that is going to make contact with the rotor.
xirtam
10-03-2015 02:06 PM
