Stance SUS and basic coil difference?
Old May 3, 2009 | 02:56 PM
Stardom's Avatar
Stardom
Default Stance SUS and basic coil difference?
Hows it goin fellas, I finally got my suspension on and realized that Stance makes a true coilover and oem style drop
my question is do they both allow the same amount of drop and also how much lower they usually drop after settling ???
thanx for the assitance guys !
Old May 3, 2009 | 06:05 PM
Stardom's Avatar
Stardom
anyone?
Old May 4, 2009 | 11:20 PM
angelzhope720's Avatar
angelzhope720
hey bud, both of the coilovers should offer the same amount of drop. i don't remember how much they "settle," it shouldn't be much. typically OEM shock + aftermarket spring combo settles the most. coilovers don't settle all too much from my experience. they should a little though.
Old May 4, 2009 | 11:56 PM
Stardom's Avatar
Stardom
well i took it apart and messed with it and realized that it isnt dropping as low as id like becuz of the factory rubber boot at the top of the spring
i know i could take it out but im sure that it will sacrifice how smooth this thing is riding right now. Is there an aftermarket one that will replace it and not be as thick...???????
Old May 5, 2009 | 09:23 AM
Thermal1's Avatar
Thermal1
Cut some of the material off of the factory rubber mount. Search. Lots of people have done it.
Old May 5, 2009 | 10:16 AM
Gsedan35's Avatar
Gsedan35
From past posts, among the guys that installed the Stance setup and gathered around to praise one another about their dropped to the weeds look,......... most all of them had the truecoilover setup. Pretty sure it will drop lower then the oem style setup. Kinda difficult when Stance doesn't bother to publish drop specs, that would bed the issue.
Old May 5, 2009 | 11:08 AM
Stardom's Avatar
Stardom
thanx for the help guys im gonna shave the rubber boot, talked to Rick at status and he helped alot, and to answer the question about how much the true coilover and oem drop supposedly its the same at least thats what Stance told me when i asked
HoBrahYouStink
Jun 24, 2016 10:58 PM
350z82
Oct 1, 2015 06:25 PM
