Brake experts please help! uneven brake feel
Hi everybody,
I have the stoptech bbk with axxis ultimate pads and I noticed that I have pretty uneven brake pedal feel. If I brake normally, let go of the pedal and brake again right after, I get much better braking response earlier in the pedal travel. Its as if I need to prime the pressure in the brake lines to get better stopping power. Could air in my lines be the cause? Bad install? Bad stainless steel lines?
I have mostly ruled out heat because the problem is still there when the pads/rotors are nice and toasty. Thanks!
theyre pointing up. not sure what my shop did. ive never bled brakes on my own either! maybe now is a good time to learn....
It's easy. There's DIY's everywhere here and on *********. I have the Motive bleeder, but if you can find a friend to help then that will be fine too. Check around your brake lines for brake fluid too, maybe they didn't tighten one down all the way.
hmm i dont think i have a leak... brake fluid level seems to be fine. i guess air bubbles are most likely cause then
The Stoptech BBK install manual (PDF) has a good description of how to bleed the brakes. There are small details that most shops probably won't do because it takes too much time. For instance, loosen one of the caliper bracket bolts so you can angle the caliper such that the bleed nipple is at the very top, allowing bubbles to go out. Then hitting it with a rubber mallet to work any loose bubbles up. Just bleed the crap out of it with a buddy.
