Nismo S-tune Vs. Bc Racing coilovers
Old May 28, 2009 | 10:47 AM
GeauxLadyZ's Avatar
GeauxLadyZ
Originally Posted by CarlosCh
Esto es correcto... la pérdida de tracción se debe a que estás dejando la suspensión extremadamente firme, lo cual sólo funciona en una pista de carreras. En carretera normal, es mejor que ande entre suave y medio.
Lo que pueden hacer es tratar con la suspensión desde el setting más suave posible y probar hasta alcanzar el resultado que necesitan.
No hace falta que se pase a la Nismo-S, con esos BC probablemente puedas llegar a lo que necesitas para andar el auto a diario.
Suerte!
/\ ...I got Nismo-S, BC, and possibly the last word in the last sentence being Diarrea...
Old May 28, 2009 | 11:32 AM
CarlosCh's Avatar
CarlosCh
Ha, ha, ha... what I said is that there is no need to jump to the Nismo-S to solve the issue, just a matter of adjusting the rear coils to a softer setting.
And ´diario´ means ´daily´, as in ´daily driver´.
Old May 28, 2009 | 12:28 PM
mcarther101's Avatar
mcarther101
^+1 try adjusting (or regulating) the dampening to a lower setting. Maybe 10 or so.
If your roads are rocky, uneven, and bad... hard (stiff) suspension will cause you to lose traction and is unsafe.
Super stiff suspension is meant for perfectly smooth and maintained track roads, not the street.
Old May 29, 2009 | 08:48 AM
alex84's Avatar
alex84
Thank you so much Carlos and rev2red.
And our roads are much better than you think guys
Old May 29, 2009 | 11:39 AM
CarlosCh's Avatar
CarlosCh
No problem, Alex.
nanotech
Oct 2, 2015 05:02 AM
