True Coilover not low enough
Old Jun 6, 2009 | 02:02 PM
Toby-22's Avatar
Toby-22
Default True Coilover not low enough
Hey guys, sorry to sound newbish but I have buddyclub coilovers on my 03 Z and for some reason the lowest it can be dropped in the rear is ~1.5" Up front i can go as low as i want but the rear wont. From what im hearing true coilover setups are suppose to give u that slammed look. Anyway my question is; if i replace the oem spring mount "which was never removed" with a rear A-arm (or whatever u call them), will my rears be able to drop some more? I've seen pics of true coilovers on other Zs and there is a bar instead of the spring mount. Any input will be appreciated.
Thanks
Toby22
Old Jun 6, 2009 | 10:23 PM
danimaldaisy's Avatar
danimaldaisy
If all you want to do is lower it more.....you can cut the rear spring mount....look up "spring mount mod"
BEFORE YOU DO THIS!!!!!!!! measure how much clearance you have from the ground to the rear Diff.......probably why it wont go any lower......
and IF you want to do the spring mount mod....order a NEW SET....and cut the old ones...just in case you want to switch back or don't like it.....I have been waiting a whole month for mine....
Old Jun 6, 2009 | 10:30 PM
GeauxLadyZ's Avatar
GeauxLadyZ
Maybe you should have bought an air suspension if you want it slammed.
Old Jun 7, 2009 | 07:16 AM
Toby-22's Avatar
Toby-22
Wow thanks man, so this will work even for true coilovers?
Old Jun 7, 2009 | 07:19 AM
DozJr7's Avatar
DozJr7
yup
Old Jun 7, 2009 | 08:05 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Explain how trimming the rear spring mount is going to alter the height on a true rear coilover (where the spring is on the damper, not separate like an OEM setup), considering the spring no longer even uses that mount anymore?
OP -
1. how are you adjusting the height? Are these coilovers 2 way height adjustable or 1 way?
Old Jun 7, 2009 | 08:06 AM
johzp's Avatar
johzp
This has nothing to do with what the OP is talking about.
He has a true coilover setup.....therefore NO REAR SPRINGS inside the spring bucket.
Hes talking about replacing the spring bucket with an adjustable toe arm like this one
If your shock body won't go any further then your either SOL or....i don't recommend this but you can adjust your springload and bring it down ever so slightly....this might or might not lower your car a little more, it just depends...also you're messing with the preload so just be cautioned.
Anyways Good luck with trying to lower your car, maybe its time for a new set of coilovers, i had to go through my share of different suspensions before i got my BC racing coilovers.
Old Jun 7, 2009 | 04:13 PM
SuperBlack350z's Avatar
SuperBlack350z
lol
Old Jun 7, 2009 | 04:38 PM
Toby-22's Avatar
Toby-22
Well i guess im just gonna have to get a different set of coilovers
Stance coilovers will be my next buy
Old Jun 8, 2009 | 04:31 AM
quakerroatmeal's Avatar
quakerroatmeal
Pictures of said the lowest it'll go? I've seen some people with BC coilovers and they had it pretty low.
Old Jun 8, 2009 | 05:27 AM
Toby-22's Avatar
Toby-22
It's the rears, the fronts can be slammed but not the rears. The main reason i bought the buddyclub was i thought all "true Coilovers" can be slammed. Shoulda done better research
May 30, 2017 03:28 PM
Dymsi
Sep 29, 2015 11:32 AM
