stock brembos vs stock brakes
Old Jun 16, 2009 | 04:20 PM
gennosuke1's Avatar
gennosuke1
Default stock brembos vs stock brakes
are they basically the same? i have read some threads to see some people say theres not much difference only it says "brembo" on it. if so why are they still expensive, just because of the name?
Old Jun 16, 2009 | 04:23 PM
0jiggy0's Avatar
0jiggy0
I dont understand your question.
Old Jun 16, 2009 | 04:30 PM
Kwame's Avatar
Kwame
They are not the same. There is a difference between the two. If you actually engage in any motor sports (aside from drag racing) with your vehicle the Brembos are superior when compared to the stock non-brembo brakes.
Old Jun 16, 2009 | 04:33 PM
LaoSiFu's Avatar
LaoSiFu
There are difference in the cooling. Less brake fade with the Brembos
~Robert
Old Jun 16, 2009 | 04:56 PM
gennosuke1's Avatar
gennosuke1
thanks for input guys. So there are 4 piston? How big are rotors and caliper
i belive rotos are about the same size as stock but im not 100 percent sure
Old Jun 16, 2009 | 06:14 PM
DavesZ#3's Avatar
DavesZ#3
Brembo rotors are larger in diameter and thickness. Yes, they are 4 piston in front, 2 in rear. Calipers are larger and made of aluminium.
Old Jun 17, 2009 | 09:05 AM
RRMikey's Avatar
RRMikey
i switch from the oem 07 brakes to brembo's... you definitly feel less fade due to the better cooling on the brembo's. also i can feel the brakes "bite" earlier when pressing the brakes. it has a much better feel than the oem. if you have the old 1 piston front and rears... they just do not want to stop from what i felt.
as for the rotor size, exactly what DavesZ#3 said.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
