Synthetic Brake Fluid
Old Jun 30, 2009 | 01:17 PM
na_350z's Avatar
na_350z
Default Synthetic Brake Fluid
Why does our Manual say NOT to use Synthetic Brake Fluid? I'm going to be flushing out all the brake fluid on my Z over the weekend and while reading the manual I see that it stated not to use Synthetic. Most Brake Fluids are Synthetic and I was thinking of running the Valvoline. Is it possible they mean not to top off the brake fluid with Synthetic or just not to use it period. Any help would be greatly appreciated.
BTW I searched but the question was never answered.
Old Jun 30, 2009 | 01:38 PM
terrasmak's Avatar
Valvoline works fine< but i now use prestone cause if a higher boiling point
Old Jun 30, 2009 | 01:41 PM
DavesZ#3's Avatar
DavesZ#3
Use exactly what the Owners Manual tells you to use:
BRAKE FLUID
Check the fluid level in the reservoir. If the fluid is
below the MIN line or the brake warning light
comes on, add Genuine NISSAN Super Heavy
Duty Brake Fluid or equivalent DOT 3
fluid up to
the MAX line. If fluid must be added frequently,
the system should be thoroughly checked by
your NISSAN dealer.
WARNING
Use only new fluid. Old, inferior, or contaminated
fluid may damage the brake
system. Do not add synthetic brake
fluid
. The use of improper fluids can
damage the brake system and affect the
vehicle’s stopping ability.
Sure, they are all "synthetic", after all, you don't see a brake fluid well and it doesn't grow on trees, right? The warning about synthetics is in regard to DOT 5 brake fluid. DOT 5 contains silicone and that will damage the rubber in the brake system of most cars.
Old Jun 30, 2009 | 01:56 PM
na_350z's Avatar
na_350z
Thanks for that information. I just didn't know the reason behind it and I was looking all over the place.
Old Jun 30, 2009 | 02:02 PM
DavesZ#3's Avatar
DavesZ#3
BTW - I've been using Valvoline for years now - you'll be fine with it.
Old Jun 30, 2009 | 04:10 PM
Done Deal DR's Avatar
Done Deal DR
DOT 4 is ok though, correct?
Old Jun 30, 2009 | 04:25 PM
terrasmak's Avatar
Correct , hell i don't even use Dot 3 in my 88 ford.
Old Jun 30, 2009 | 05:17 PM
na_350z's Avatar
na_350z
Thank you sir... I'm sure this will answer for those looking in the future.
Old Jul 1, 2009 | 03:30 AM
Done Deal DR
Thanks terrasmak.
I figured being that I've been running RBF600 for 2 years without issue that was the case.
Old Jul 1, 2009 | 03:21 PM
armt350z's Avatar
armt350z
DOT 3, 4 and even 5.1 are perfectly fine to use as they are all glycol based. dot 5 is the only DOT rated fluid made of silicone thats commonly available.
Stevo Z
Oct 3, 2015 09:14 PM
samansharif
Sep 25, 2015 12:31 PM
