Installing SPC camber kit and toe bolt
Old Jul 3, 2009 | 10:37 PM
JonnyRod's Avatar
JonnyRod
Default Installing SPC camber kit and toe bolt
I know there is a thread on replacing the toe bolt, but how about a DIY on replacing the rear camber arms? I purchased a set of SPC rear camber arms w/ toe bolts, and even though the install looks pretty straight forward, are there any hints/tricks to know before I start?
Old Jul 3, 2009 | 10:44 PM
JasonZ-YA's Avatar
JasonZ-YA
The camber arm install isnt covered anywhere, because its really as simple as remove old, install new...........reuse same bolts...
if anything, when you remove the old, spin the new spc one to about the same length as the non adjustable oem camber arm, then reinstall........
remember, as soon as your done, drive to alignment shop..
-j
Old Jul 5, 2009 | 02:06 PM
JonnyRod's Avatar
JonnyRod
awesome...thats all I was looking for, thank you
Old Jul 5, 2009 | 05:59 PM
guitman32's Avatar
guitman32
Also make sure to leave about an equal # of threads on either side of the adjuster on the new SPC arm.
Old Jul 6, 2009 | 04:12 AM
JasonZ-YA's Avatar
JasonZ-YA
yes, exactly.....sorry, im thinking that, but not writting it....assuming you know...yeah leave equal amount so that the same amount of shaft is threaded in for strength and not short on one end or the other..
-J
Old Feb 3, 2011 | 03:25 PM
mr.elite's Avatar
mr.elite
Dont forget to loosen up the swaybar bolts.
Old Feb 3, 2011 | 04:10 PM
terrasmak's Avatar
Actually the 4 bolt for the sway bar need to be removed , and the 3 bolts per side for the plastic fairing under the car need to be removed.
HoBrahYouStink
Jun 24, 2016 10:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
