Rear Mount Bolt Problem
Old Feb 3, 2011 | 07:06 PM
Nateclipse's Avatar
Nateclipse
Default Rear Mount Bolt Problem
So i fugged up and stripped the bolt nut. I've tried everything to get this thing off. Ive even tried using the dremel tool but not having any luck. Does anybody have any suggestions on how to get this off? Any help would be appreciated greatly! added pictures of the bolt nut.
Old Feb 3, 2011 | 07:39 PM
terrasmak's Avatar
First of all , use quality tools. Second , first time you break those free you 6 point socket is a must. Last , i would throw a nut removing socket on it http://www.sears.com/shc/s/p_10153_1...u=00952166000P and hope you didn't screw up the threads.
Old Feb 3, 2011 | 07:43 PM
vtchang's Avatar
vtchang
^ I made the same exact mistake and used the same exact socket extractor set. Those extractors are awesome.
Old Feb 3, 2011 | 10:22 PM
redman333's Avatar
redman333
You can also get a socket that's slightly too small and hammer it on and then take it off that way. You may not be able to get the nut out of the socket afterward though. Not the best way but if you don't want to buy tools you can try that.
Old Feb 4, 2011 | 09:45 AM
beezee's Avatar
beezee
Spray some PB Blaster on it to help loosen any rust. Whatever the case be careful not to break the bolt. (Yes it is possible). A guy broke his. They are welded in, and cost bucks to have one replaced
liqalu04
Jan 2, 2022 12:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
TDPrank
Sep 29, 2015 12:51 PM
samansharif
Sep 25, 2015 12:31 PM
