g35 Eibach Sportlines on a 350z
Old Jul 29, 2009 | 07:07 AM
KBurn's Avatar
KBurn
Default g35 Eibach Sportlines on a 350z
I got a set of g35 sportlines for free but i was wondering if they would work on my Z? im only looking for a 1 inch drop or so, nothin crazy. I figured since the sportlines sit pretty low...on the Z it would sit a little higher and be where i want it. Im wondering how much of a drop it would be, Has anyone ever done this?
Old Jul 29, 2009 | 07:38 PM
1001's Avatar
1001
the website claims it lowers 1.6 front and 1.4 rear for the g35 and the Z ones lowers 1.2 front and 1.2 rear. i just got my sportlines installed and i only have 1 finger gap front and rear on oem 18s.
Old Jul 29, 2009 | 07:50 PM
jkim824's Avatar
jkim824
Are you lowered on stock shocks? and if you dont mind can you PM me how much your whole lowering process cost. Thank You
Old Jul 29, 2009 | 08:25 PM
KBurn's Avatar
KBurn
Hmm so since the Z is lighter these springs should work? I read that the Z will sit about .5" higher with G springs so it should be around the same drop as normal sportlines?
Old Jul 30, 2009 | 09:36 PM
1001's Avatar
1001
if they do sit higher, you'll be looking at 1.1 front and about 1 inch rear but when the spring settle after a few day, it'll go lower. BTW...are these new??? i think these might be lower than what you want.
Old Jul 31, 2009 | 01:59 AM
KBurn's Avatar
KBurn
I want to lower it just enough so i wont need a camber kit so im thinking just like 1 inch. I think these might still put me over that if they lower the G 1.6
Old Jul 31, 2009 | 09:04 AM
zete350's Avatar
zete350
You are probably going to need a camber kit in the rear even with a 1 inch drop. Some people are lucky enough to be able to get an alignment to fix their camber and toe with just a 1 inch drop. But the majority needed a camber kit. Every car is different though. You may be one of the lucky ones that just needs an alignment.
Old Jul 31, 2009 | 11:11 AM
KBurn's Avatar
KBurn
Hmm well since the springs were given to me i might as well buy a rear camber kit. I have a free day today and i just want to get it done. It should be alright to run my car for a few days out of spec with the springs right?
Old Jul 31, 2009 | 01:32 PM
zete350's Avatar
zete350
Yes, you should be fine. Are the springs new? If they are, wait about a week, maybe a bit longer, after you put on the springs to get the alignment done. Because if they are new, they need time to get broken in and they will sag a bit.
Old Jul 31, 2009 | 05:22 PM
KBurn's Avatar
KBurn
I put the rears on today and it dropped it nicely, exactly how i wanted it. The springs were used so their pretty much settled. Still need to do the fronts tomorrow.
Went from this:
To this:
Old Jul 31, 2009 | 09:09 PM
zete350's Avatar
zete350
Nice! What a difference an inch makes.
Old Aug 4, 2009 | 09:11 PM
wholepearl's Avatar
wholepearl
Default say hello everyone
Hi, I am new here. I viewed all posts. ------------------------------------------------------------------------------good jewelry onlineHandbags, watches wholesale bridal jewelry in western pasterling silver jewelry wholesalepandora jewelry retailers
Old Aug 5, 2009 | 12:06 AM
eddiebrock71's Avatar
eddiebrock71
Have you done the fronts yet. If so could you post some pics with the fronts installed.
Old Aug 5, 2009 | 08:59 AM
loudrims_inc's Avatar
loudrims_inc
Went from this:
To this:
niceee
Old Aug 7, 2009 | 02:54 PM
brasil350's Avatar
brasil350
I'm about to lower my car with springs alone. Do you think It will affect the life/quality of my shocks??
Old Aug 7, 2009 | 03:15 PM
KBurn's Avatar
KBurn
I tried doing the fronts today and their such a pain to do. I could not figure out how to get the struts off after unbolting everything. After about an hour on one side i just put it all back together and gave up. Pep Boys said they would install the front springs for me and do an alignment for $250 so i may go with that.
Old Aug 7, 2009 | 05:13 PM
terrasmak's Avatar
As with any car , yes lowering spring will destroy stock shocks quickly.
Old Aug 9, 2009 | 05:42 PM
XSpeedAddictX's Avatar
XSpeedAddictX
I have them, they are a horrible ride but the look is amazing.
Old Aug 16, 2009 | 08:33 AM
jeeriko's Avatar
jeeriko
Explain horrible. I'm thinking of going w/sportlines, but undecided now.
Old Aug 17, 2009 | 10:30 AM
redlude97's Avatar
redlude97
progressive design, soft initial rates, pretty much blah all around if you care about performance at all. Unfortunately most people here are only concerned about the look and don't really care how the car handles
