Do the stock brake setup on all Z's suck? Mine sure do!
To the OP, list your entire setup and we may be able to tell you what is wrong. Include the following info:
1. pads - type and age
2. rotors - type and age
3. fluid - age
4. tires - type
To give a point of reference, I just swapped out my rotors for slotted stop techs and I've been using metal matrix pads for some time now. my 03 stops extremely well. Planning to do my fluid in a week or two. Your Z should be stopping well. If it isn't, something isn't right and if you post the info, we can help you figure it out.
i have a question concerning my stock brakes
when i stop suddenly, and very hard (maybe when going around 30mph+) i feel a vibration in the brake pedal, it feels almost like im feeling the ground through the pedal
is this known as brake judder? What causes this?
As mentioned before, it could be your ABS engaging which feels more like a pulsation in the pedal along with some noise coming from either the front or rear, depending on which side engaged ABS. If it is not ABS, you probably have deposits on your rotors that cause the vibration when you push them a little harder. You can try and re-bed the rotors to clean them off and see if this fixes your problem. StopTech's procedure:
http://www.stoptech.com/tech_info/wp_bedinstock.shtml
newbs newbs newbs. the stock brakes on the Z are fantastic with the oem pads and with the system bled properly. the car stops on a dime with the stock system with lots of bite. for the track.. not so much but for daily driving they are more than adequate almost exceptional.
Can you recognize when your ABS engages? Just trying to gauge your level of experience with brakes.
no im pretty sure its not my ABS. I know what ABS engaging sounds like. you can hear slight noise and there is a "hum" on the brake
whats happening to me is when im driving along 30-40mph and lets say for example, I need to do a sudden stop because some lady's dog runs out into the street lol. What i would then experience is a somewhat hard shaking on the brake pedal. not a faint vibration, but there is definite movement/shaking on my brake pedal
and yeah ill try that bedding procedure see if it helps
what if they are my calipers? What's the procedure i should follow if this is the case? If its the rotors i know I can just buy new rotors but if its the calipers would I just have to purchase a completely new brake system (can you just buy new calipers?)
You can purchase new calipers, in many different formats. Buy OEM PARTS!!!! Personally I reccomend replacing your calipers in pairs at the very least. It's not always required, but, keeps your brake system balanced in my opinion, and it beats having to do the same thing a few months down the road if the other one starts to go out too. There's plenty of vendors here, and over my last two Z's I've ordered all my OEM parts through Courtesy Nissan. Good prices and nice diagrams, not to mention the staff is a ton better than any of the local dealerships where I'm from.
I have an 04 Z touring, and just replaced the front and rear rotors/pads (Akebono) because I felt as if the car wasnt braking as fast and hard as it should. Since changing them, the car feels exactly the same. I'm scared to even push the car all that hard because if I need to suddenly brake, I'm gonna rear end somebody.
Is this just the way the car is? Or is something wrong with mine?
BTW: The emergency brake on my car doesnt work all that well either. It's been this way since I purchased the car. Can this be fixed or adjusted somehow?
I have an 03 touring and my brakes work fine. The car is autox and tracked with no problems. Running Carbotech pads, amsoil brake fluid, stainless lines, and R1 concept rotors. Soon to be adding brake ducts and they are the non-brembo's. I added speed bleeders and they make changing fluid a breeze.
Got them through Jegs, best price I could find. Makes bleeding your brakes very easy and a one man job.
http://www.russellperformance.com/mc...domestic.shtml
The G35 needed them in 2005. It's also probably cheaper to offer the same brakes as base on the Z, than it is to manufacture both.
Terry
Really?
I've heard of a few pounds here and there, but has anyone ever confirmed that between the two cars? 175 pounds is quite a bit of weight gain for really no major changes
The bumper is redesigned but I didn't think it was any longer...
