SPC Front Camber Arms the worst?
Old Aug 16, 2009 | 06:12 AM
Diesel350's Avatar
Diesel350
Default SPC Front Camber Arms the worst?
I have read some comments on the site that the SPC Front Camber Arms are the worst you can buy, I wanted to know what makes them the worst compared to SPL or Cusco. I am shopping for front camber arms but don't want to spend a ton of money. What would be the best front camber kit for the money?
Old Aug 16, 2009 | 10:39 AM
garage-c's Avatar
garage-c
SPLParts hands down.
Old Aug 16, 2009 | 01:23 PM
Tac-M's Avatar
Tac-M
spl parts
/thread
Old Aug 16, 2009 | 02:40 PM
Sleepy79's Avatar
Sleepy79
what a wealth of knowledge
Old Aug 16, 2009 | 04:27 PM
terrasmak's Avatar
What are you goals? Race car , trackday car , just want neg camber for stupid offset and mega stretch ?
Old Aug 16, 2009 | 05:31 PM
jruocco's Avatar
jruocco
I am in the same boat as you. I hear good and bad things about the SPC front camber arms. I looked at the SPL but they would be overkill unless you are planning on some serious track time. The cusco are meant more for running negative camber from what I have found out. Seems a lot of people max out the positive camber trying to get the car back in spec.
Old Aug 16, 2009 | 05:46 PM
Diesel350's Avatar
Diesel350
I just need to be able to get my camber back in OEM spec. No track time just daily driver.
Old Aug 16, 2009 | 05:55 PM
Sleepy79's Avatar
Sleepy79
The only issue i have read about is the abs relocation bracket. That is only if you choose to install the spacer between the hub and steering knuckle.
SPC did have another issue with their design. The castellated nut that mates with the ball joint was not flanged. They claimed that there a few cases where the nut had actually pulled through the steering knuckle assembly. SPC did send out washers to correct this problem, or you could reuse the oem flanged nut.
Old Aug 16, 2009 | 10:32 PM
Chebosto's Avatar
Chebosto
cusco a arms are somewhat limited by the amount of negative camber you can run from factory. you have to modify the slots in which the pivot joint sides/slides, from this image, remove the six silver bolts, shave the rounded part closes to the straight edge and slide the whole piece inward to get more negative..
the rubber around the joint:
tends cracks, and you might want to get a better cover for dust / road grime protection.
they are very easy to adjust at the track, and relatively inexpensive. i've used them for several years now and i have no complaints.
the SPLs are very very nice. i would upgrade to those if i didnt have the cusco ones already.
Old Aug 17, 2009 | 07:53 AM
guitman32's Avatar
guitman32
Quick search for prices:
Ichiba: $327
SPC: $385
Cusco: $384
SPL: $499
In my opinion, the extra money for the SPL pieces is worth it.
Old Aug 17, 2009 | 08:27 AM
tnk210's Avatar
tnk210
I bought the SPC for the main purpose of bringing the camber back to spec. They've worked great for me and I have no complaints.
Old Aug 17, 2009 | 09:37 AM
Thermal1's Avatar
Thermal1
Since all you want is to bring it back to factory specs, the SPC will work fine for you.
Also consider Ksports. i have them and they are a very nice piece. My only complaint is the paint on them is not very durable.
Old Aug 17, 2009 | 10:28 AM
redlude97's Avatar
redlude97
SPC is the only arm that offers more than ~1 degree of positive correction without fenderwell modification due to the spacers that are included. Those are what a majority of people have trouble with, but if you need more than 1 degree of correction, than SPC is the only one that can provide it. The actual arm is somewhat heavy and has had some clearance issues on very low cars or softer than stock springrates, but they are far from the worst kit out there. A few others come to mind like kinetix etc. IMO, the best setup would be SPL arms with the SPC spacers for the widest range in adjustability
Old Aug 17, 2009 | 07:57 PM
guitman32's Avatar
guitman32
Id be curious how the weights of the various arms compare. Being milled aluminum, I assume the SPL would be the lightest of the bunch.
Old Aug 17, 2009 | 11:15 PM
Doh-Joe's Avatar
Doh-Joe
^+1
I kept my stock bracket back in after ABS light came on and haven't had any issues since.
Old Aug 18, 2009 | 03:29 AM
Sleepy79's Avatar
Sleepy79
Still waiting to hear the bad about these arms. I know one vendor on here stated that would not even carry them at all.
Old Aug 18, 2009 | 04:01 AM
JasonZ-YA's Avatar
JasonZ-YA
do you have any pics of your Ksport's on your car?
Old Aug 18, 2009 | 04:02 AM
JasonZ-YA's Avatar
JasonZ-YA
Where exactly are you trimming the "straight side"??? So you mean closest to the car side?
-J
Old Aug 18, 2009 | 08:51 AM
Chebosto's Avatar
Chebosto
-J
"straight edge" aka closes to the frame of the car. the rounded part (top of the pivot joint head) hits first before the plate due to the semi-circle cut out-
use a high speed rounding tool to arc out the rounded edge.. you'll destroy the two most inner bolt holes but that's ok. the plate is held in on the sides anyway. to shove the plate with the joint as far in as it can go.. (you can even flip/insert the plate the other way, i think one side is even shorter than the other...
i modified it to get me around -3.5.. feels good on the turns w/ the r888s.
Old Aug 19, 2009 | 09:26 AM
Diesel350's Avatar
Diesel350
My camber is currently at -1.68 Degrees
