Can't align to specs.
Old Aug 24, 2009 | 11:32 AM
gyotar's Avatar
gyotar
Default Can't align to specs.
I took my '03 Z Touring into the shop to have it aligned to save the front right tire which is getting heavy feathering. They couldn't get it into specs.
They are trying to tell me that I need new springs to get it into specs. I realize that the new springs will help align the car in the short term by increasing ride height a little, but won't I be in the same position once the springs settle?
I have 20" rims so I am not lowered and using all stock parts.
What is an affordable front and rear alignment kit for a daily driver to put everything into specs?
I'm sure this is talked to death but thanks for your input!
Old Aug 24, 2009 | 12:14 PM
terrasmak's Avatar
Go to a different shop, and please post your alignment specs so we can look at them.
Old Aug 24, 2009 | 12:16 PM
Motormouth's Avatar
Motormouth
get rid of the 20s.
solved.
but that serious advice aside (you should of course do that), it sounds like your car has accident damage.
Old Aug 24, 2009 | 12:30 PM
gyotar's Avatar
gyotar
No accidents, however it would be a hell of an accident for all 4 wheels to be out of alignment. I'll try and get the sheet up after work.
Old Aug 24, 2009 | 12:38 PM
gyotar's Avatar
gyotar
Readout says I have 18" wheel. not sure if that makes a difference.
Left Front
-1.5 Camber
8.3 Caster
0.05 Toe
Right Front
-1.4 Camber
8.2 Caster
0.05 Toe
Front
0.0 Cross Camber
0.1 Cross Caster
0.1 Cross Toe
Left Rear
1.6 Camber
0.1 Toe
Right Rear
-2.5 Camber
0.13 Toe
Rear
0.23 Total Toe
-0.02 thrust Angle
Old Aug 24, 2009 | 12:52 PM
Motormouth's Avatar
Motormouth
I could've sworn you said the issue was the left front or something.
Old Aug 24, 2009 | 12:54 PM
JasonZ-YA's Avatar
JasonZ-YA
20 inch wheels alone will throw your car out of spec, and the stock alignment bolts wont bring it into specific range...
I would defiantly try another shop, because them telling you that you need to buy springs is bull, they are trying to make a sale.....
The front, the only thing they can do is adjust the tie rods........if not you need to buy front upper control arms....many people that purchase 20's learn this "after-the-fact" and never buy whats needed to get the car back into spec..........car ends up looking like crap (due to crazy camber) and tires wear super fast and then they cry about it later....I have seen it......buddy of mine wouldn't listen..
Front:
If a good alignment shop cant get it in spec with tie rods, which im more than certain you cant! you need front upper control arms to adjust alignment....
Springs do nothing! 350z don't have camber plates, etc..its not a 240sx. its an SLA suspension design.
350z upper control arm: http://www.enjukuracing.com/megan-ra...223ed532e05f4e
REAR:
Buy the rear toe bolt and rear camber arm.
Toe bolt install: http://www.batit.com/forumpics/spctoeboltinstall.pdf
Buy both here or similar place:
http://www.iapdirect.com/product.php?productid=40163
due to this statement, I provided links to the most basic parts for a daily driven car, if it were a track car, etc, i would link you nicer/more adjustable stuff......
-J
Old Aug 24, 2009 | 12:55 PM
terrasmak's Avatar
You need a camber kit for the rear, -1.5 front is fine, out of specs but with your toe in spec you will not have problems.
Jason , with the camber he has, his car has to be lowered. The wheels won't cause that, i bet the previous owner installed drop springs.
Old Aug 24, 2009 | 12:58 PM
JasonZ-YA's Avatar
JasonZ-YA
^ yes i agree with smack ---- now that i see he posted his alignment specs....if the -1.5 is correct? -- i dont like the statement of him saying the sheet says 18 inch wheels......if the alignment was done wrong, then those numbers he posted are useless..
-J
Old Aug 24, 2009 | 01:02 PM
Motormouth's Avatar
Motormouth
the only issue with front alignment should be camber - which isn't really an issue. anything else being out of whack (your toe if you are getting feathering I believe) says something is wrong... worn tie rods maybe?
your front specs look fine though. just your one rear rim is way out, which again... hit a curb, I don't know. Sounds like they ****ed it up possibly.
toe bolts are cheap as hell though, and easy to install, if necessary.
Old Aug 24, 2009 | 01:06 PM
gyotar's Avatar
gyotar
The 20's came with the car when I purchased it so I didn't really go out of my way to get them. I seem to be getting heavy flak for them. Oh well.
When I get new tires next season I'll be sure to take the car to a forum recommended alignment shop in Toronto. I'll probably throw in the suspension parts over the winter. Thanks for the links and info.
Old Aug 24, 2009 | 01:27 PM
20 inch wheels is a baller set up. This alignment stuff is overrated. Rolling in style.
Old Sep 24, 2009 | 07:13 AM
gyotar's Avatar
gyotar
I'm having the SPC Front/Rear kits installed in a week or two so I was wondering what the latest and greatest alignment specs were for all 4 wheels to maximize tire life. I've been searching but can't find a straight answer.
What I was thinking was to run as little camber and as much toe in as the latest tsb allows for...however I don't know the latest TSB alignment specs.
Old Sep 24, 2009 | 08:45 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
consult the factory service manual and set it to the least aggressive specs in the specified range
Old Sep 24, 2009 | 09:15 AM
Motormouth's Avatar
Motormouth
why did you buy a Z if you are willing to make it understeer like a beotch by removing all yo camberz?
come on dawg, be ballin player fo real son. ya herd?
Old Sep 24, 2009 | 09:22 AM
gyotar's Avatar
gyotar
lol whatever wanksta
Old Sep 24, 2009 | 09:23 AM
Motormouth's Avatar
Motormouth
I comes correct balla, don't be hatin' cuz yo wack and sheit
Old Oct 5, 2009 | 07:18 PM
stinky350z's Avatar
stinky350z
^ u guys r funny lol
Old Oct 6, 2009 | 02:40 AM
gyotar's Avatar
gyotar
SPC kit installed. Front/Rear. Everything went fine with the install. The shop didn't set the gap for the ABS sensor but I shimmed it correctly at my own shop and all the lights went out. In spec all around.
Thanks for you help guys.
Old Mar 20, 2019 | 06:33 AM
specialized5223's Avatar
specialized5223
I just got an alignment and they brought everything to factory spec except camber in two corners, told me things could be bent; vague to say the least... They advised replacing shocks, toe bolts and camber plates. Just makes me curious.
Camber was out in those two opposing corners by .7 deg.
