Still rubbing after fender roll
Old Sep 1, 2009 | 01:44 PM
BarefootRacer's Avatar
BarefootRacer
Should have gotten an alignment before you rolled the fenders. That setup should be no where close to rubbing.
Old Sep 1, 2009 | 02:33 PM
redlude97's Avatar
redlude97
where is it rubbing?
Old Sep 6, 2009 | 01:41 PM
o2sys's Avatar
o2sys
The passenger side rear is rubbing on the fenders. Dont know exactly where since i am driving when its happening.
I got the aligment done today and its still rubbing! Is not rubbing as much, now its only happening during hard bumps ans dips.
With the S-techs i was only able to get it to -2.0 camber on the rears...
Old Sep 7, 2009 | 06:32 AM
o2sys's Avatar
o2sys
posted some pix...does that part even need to be rolled?
Old Sep 8, 2009 | 12:17 PM
o2sys's Avatar
o2sys
Bump/help
Old Sep 8, 2009 | 01:22 PM
DISH903's Avatar
DISH903
Originally Posted by o2sys
Setup: 19x8.5 255/40/19 Rear with 33 offset + 25mm spacer.
Problem: Passenger side rear still rubs after fender rolling.
Suspension: Tein S-tech Z specific.
I think its an alignment problem, it rubbed even before i recently installed the s-techs. I did an aggressive fender roll thinking it would solve the problem but still persists.
Can stock rear suspension be out of spec (stock range)?
UPDATES:
I went for an alignment the most the tech could give me was -2.0 camber on the rears.
Also here is a pix of the passenger side rear fender which i think its the part its rubbing.
From the pics you posted, I wouldn't say you have an "aggressive" fender roll. Try rolling them ALL the way down and that should fix your problem.
Old Sep 8, 2009 | 03:59 PM
o2sys's Avatar
o2sys
The roll itself is pretty aggressive, its almost folded flat. I just didnt know you had to roll all they way down there. The back is rolled all the way to the rear bumper.
Does it even touch that area? If so the driver is the same but is not rubbing...
Old Sep 9, 2009 | 06:11 AM
o2sys's Avatar
o2sys
Originally Posted by 1FreshG
Wow i hope you didn't pay much for that roll, you def. need to go farther down, you can see that the tire is pulling the lip out/down. Needs to be rolled more!!!
I paid a local guy from my subaru forums $20 to do it...i guess i can ask him to do the additional 6" or so.
Old Sep 14, 2009 | 07:21 AM
o2sys's Avatar
o2sys
Okay, i rolled the fenders couple inches more from the pictures i posted. This has solve the problem. No more rubbing what so ever.
Thanks for everyone's help and input!
Obadabot
Jun 18, 2023 11:31 PM
Justin100
Nov 25, 2021 06:26 AM
