Still rubbing after fender roll
Old Aug 26, 2009 | 06:50 PM
o2sys's Avatar
o2sys
Default Still rubbing after fender roll
Setup: 19x8.5 255/40/19 Rear with 33 offset + 25mm spacer.
Problem: Passenger side rear still rubs after fender rolling.
Suspension: Tein S-tech Z specific.
I think its an alignment problem, it rubbed even before i recently installed the s-techs. I did an aggressive fender roll thinking it would solve the problem but still persists.
Can stock rear suspension be out of spec (stock range)?
UPDATES:
I went for an alignment the most the tech could give me was -2.0 camber on the rears.
Also here is a pix of the passenger side rear fender which i think its the part its rubbing.
Old Aug 26, 2009 | 07:08 PM
Gibbs's Avatar
Gibbs
Know it all
Maybe the shocks are bad.
Old Aug 26, 2009 | 08:11 PM
ekidd's Avatar
ekidd
Im not sure how youd be rubbing. You didnt even need to have your rear fenders rolled for that setup.
Old Aug 26, 2009 | 08:55 PM
vthao's Avatar
vthao
Damn, rubbing on S-techs huh? Hmm. I'm sure your alignment may be off. Do you have a rear camber kit? If so, get a full four wheel alignment. If not, buy a camber kit and get an alignment
Old Aug 26, 2009 | 09:22 PM
o2sys's Avatar
o2sys
is not cuz of the stechs or tire setup, i definitely think its my stock alignment...
But what i'm confused is that from what i've read stock has no adjustments what so ever, so how can my rear's be "out of spec" even before i installed the springs?
Old Aug 27, 2009 | 04:30 AM
cheshirecat79's Avatar
cheshirecat79
Get an alignment.
Old Aug 27, 2009 | 05:51 AM
o2sys's Avatar
o2sys
i will wait about a week for the springs to settle before i get an alignment...
Old Aug 27, 2009 | 06:27 AM
terrasmak's Avatar
Your alignment is probably way off, get an alignment and see what happens. Yes there is two rear adjustments.
Old Aug 27, 2009 | 08:52 AM
GeauxLadyZ's Avatar
GeauxLadyZ
PICS!!!
Old Aug 27, 2009 | 10:46 AM
o2sys's Avatar
o2sys
Originally Posted by GeauxLadyZ
PICS!!!
of my current alignment?
Old Aug 27, 2009 | 12:28 PM
GeauxLadyZ's Avatar
GeauxLadyZ
Ya, of current setup...rears only.
Old Aug 27, 2009 | 12:37 PM
WXSigns's Avatar
WXSigns
Vendor - Former Vendor
Are you running stock shocks?
Are you rubbing all the time or just when you hit dips in the road?
My rear tires have a 3/8" gap off the fender with H&R coilovers and I have no rubbing with 295/35/18 +20 offset. Even without the camber kit I didn't rub.
Old Aug 29, 2009 | 02:16 PM
hkman78's Avatar
hkman78
I also have a similar problem like on my passenger sidear rear after I rolled my fender. But most the time the rubbing happen only when I make a right turn into a upward driver way or into a plaza. My car also feel floatly when I try to push it after coming out from a turn.
Here is my setup: I am running 255/35/19 +17 offset front and 285/35/19 +18 offset rear. I have a rear camber kit only. The alignment on the rear is actually w/in factor spec. But my front aligment is slight off factory spec. So I wonder if it is because my aligment.
When I was running 245/35/19 and 275/35/19 w/o camber kit, I didnt have any problem. So I wonder if it is because my alignment is not balance or perhaps my shocks are done.
Can some suspension expert please chime in?
Old Aug 31, 2009 | 07:38 PM
Mike@Blackline's Avatar
Mike@Blackline
58mm offset? pics
Old Sep 1, 2009 | 08:33 AM
terrasmak's Avatar
Not all cars are built perfect, or even close. Your fenders could be off as much as 1/16 or more from each other, and once rolled the number is even greater. Also your camber, if your really close to rubbing, just 0.1 degree could make it happen on one side and not the other.
Old Sep 1, 2009 | 08:49 AM
Jun's Avatar
Jun
Adjust your camber in, or get smaller spacers?
Old Sep 1, 2009 | 08:50 AM
o2sys's Avatar
o2sys
Originally Posted by Mike@Blackline
58mm offset? pics
Wouldn't it be considered +8 offset? Well anyways, i tried to take picture of the car but the difference is so minuscule that i't can't be noticed with picture or naked eye....
Old Sep 1, 2009 | 08:51 AM
o2sys's Avatar
o2sys
Yea i'm just letting the springs settle a bit before i go in for alignments...
Old Sep 1, 2009 | 09:05 AM
JDMFairlady21's Avatar
JDMFairlady21
dude OEM rear has camber adjustments
def need a slight adjustment towards the negative side. take a pic of the setup now
Old Sep 1, 2009 | 09:09 AM
o2sys's Avatar
o2sys
i was rubbing even before the spring install
