steel braided brake lines + oem brakes good?
Old Sep 21, 2009 | 06:35 AM
nismo_nate's Avatar
nismo_nate
Default steel braided brake lines + oem brakes good?
hey guys,
i need to get my brakes replaced, i was wondering if i get the steel braided brake lines + oem brakes (can't afford big brake kits lol).. will it make a difference in braking? since the braids won't expand i should feel a difference correct? would there be a difference in braking distance?
i am thinking of buying Z1 brake lines
thanks in advance
Old Sep 21, 2009 | 06:36 AM
Goku350z2007's Avatar
Goku350z2007
get hawk break pads + the steel break lines and you will feel a big difference.
Old Sep 21, 2009 | 07:23 AM
nismo_nate's Avatar
nismo_nate
would you recommend crossdrilled rotors? or oem's would do?
are Z1 lines good enough or will another brand be better?
thanks
Old Sep 21, 2009 | 07:40 AM
quakerroatmeal's Avatar
quakerroatmeal
I got stainless steel braided lines because a lot of people claimed they made a huge difference. I can't even honestly say if I felt a difference or not...and the fluid was even properly flushed and switched with motul.
Old Sep 21, 2009 | 10:44 AM
guitman32's Avatar
guitman32
+1. When I installed my stainless lines, and as one would expect after a brake job (new pads, rotors, SS lines, fresh fluid flush) I felt a solid, firmer brake pedal. I can't honestly attribute this to the SS lines though.
I'd say if you've got track time in your future it's probably worth the upgrade, but if you're just street driving definitely not worth the time IMO. If anything you'll notice an improvement in braking modulation. I'd challenge anyone who says you're going to see shorter stopping distances as a result of SS lines alone to prove it.
Old Sep 21, 2009 | 10:46 AM
guitman32's Avatar
guitman32
Any brand lines from a reputable manufacturer should be fine, and for rotors I would recommend blank rotors (not slotted or drilled) if you can find them (try Centric premium blanks).
Old Sep 21, 2009 | 11:07 AM
ANXIOUZ's Avatar
ANXIOUZ
Stainless lines do make a difference but I found out recently that bleeding the lines and replacing the fluid made a HUGE difference in my pedal feel. Stainless lines are like $75 and worth it IMO.
OEM rotors are fine but I'd recommend Hawk HPS pads as well. Much better. But if you need rotors check out something like SP slotteds. I got new SP slotted rotors + Hawk pads all-around for something like $350 OTD from Dynamic Autosports in Lake Forest. A local dealer wanted $450 for just 1 OEM rotor alone. This was for an Evo but the concept is the same.
Old Sep 21, 2009 | 08:09 PM
Goku350z2007
i got my slotted drilled premium rotors from R1 comcepts, there is no need to get the slotted drilled rotors its just for looks, just get the slotted ones you'll be fine
Old Sep 22, 2009 | 01:18 PM
o2sys's Avatar
o2sys
SS lines are more for pedal feel and consistency. Rubber line get fatigue by heat and expand. SS line don't so it will have better pedal feel and fade resistance than rubber lines. I don't think it suppose to make you stop better. That job is for the tires.
Old Sep 22, 2009 | 02:01 PM
TheFarmer's Avatar
TheFarmer
For those who track, SS lines will make a big difference. Especially when the brake fluid heats up.
Ace2347
Sep 22, 2015 03:12 AM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
