Alignment Question
Old Sep 24, 2009 | 06:10 PM
fick's Avatar
fick
Default Alignment Question
I have an 03 that drifts slightly to the right on the freeway; not bad but just enough to be a little irritating. The car does not have the feathering or road noise problem. I would like to have it aligned but have heard that the 03's have had to have their alignment changed to fix the tire feathering problem. I don't want to introduce a new problem; is there anything I should be aware of in having the car aligned? Will the dealer or shops have the correct specs? What was done on the recalls to fix the feathering problem? The original owner I bought the car from said he had no problems but did take the car in for 2 recalls just to be sure.
Old Sep 24, 2009 | 06:14 PM
DavesZ#3's Avatar
DavesZ#3
Moved to proper forum
Nothing to worry about. Any decent shop will have the most current alignment specs in their machine.
The "fix" for feathering was to set the proper toe-in on the front wheels.
Old Sep 24, 2009 | 07:27 PM
fick's Avatar
fick
Thanks!
Old Sep 24, 2009 | 10:42 PM
st8king's Avatar
st8king
have your alignment checked often as well. My Z does not hold an alignment for crap. In six months I was way out and had toe in on the front and rear tires cost me a set of tires all the way around loud feathering in the front and worn out in the rear on the inside.
Rich
Old Sep 25, 2009 | 04:54 AM
nixy's Avatar
nixy
I had this issue on my 2003. The noise from the bridgestones at low speed was dreadful and two of the tyres were badly worn on the insides. I got new tyres and then had a laser alignment done and its been fine since.
Old Sep 27, 2009 | 07:26 PM
st8king's Avatar
st8king
How long has it been I had fresh tires had the laser alignment done and 8 months later tires were trashed. Put the rear set on last month and got another alignment. Four weeks later had a new front set installed and had alignment checked toe in was way off again.
Rich
Old Sep 28, 2009 | 12:34 AM
nixy's Avatar
nixy
Mm, very odd - that was a whole year ago - not had any more problems since with uneven wear or noise and it was VERY bad before.
issyz
Jul 2, 2017 03:04 PM
Depravity
Oct 1, 2015 04:49 PM
Alexreyes
Sep 30, 2015 11:30 PM
