How do you adjust ride height/damping force
Old Oct 28, 2009 | 06:54 PM
Wild350z's Avatar
Wild350z
Default How do you adjust ride height/damping force
Hey everyone, i know on some coilovers, you must change the damping front the top and other are with adjustable tools. My question is changing the damping and height, the same thing? And if different how do you change both on a Megan Racing Coilovers and on a Basic Tein Coilovers?
Old Oct 28, 2009 | 07:13 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
dampening and height adjustment are different
megan - no idea
tein basic - only height is adjustable, not dampening
Old Oct 28, 2009 | 08:58 PM
aaronz8's Avatar
aaronz8
dampening means the hardness or softness of the ride. Height is... obvious.
Old Oct 29, 2009 | 08:53 AM
labelworkshop75's Avatar
labelworkshop75
for mine (Stance coilovers) To adjust dampening you turn little ***** on the tops of the whole assemble (under the hood for front coilovers). Left is softer. Right is stiffer. To adjust height you must jack the car. Take off wheel. Unlock the locking nut on the coilover. Then the whole threaded peice of the coilover spins. Spin into the base (down) to lower. Spin up and out of the base of the coilover to raise
Old Oct 30, 2009 | 12:01 AM
Wild350z's Avatar
Wild350z
Is there a way to spin all 4 bases down to the exact point? i mean i know its possible, but how do you know they are all set to the exact right spot?
Old Oct 30, 2009 | 05:48 AM
Z1 Performance
Former Sponsor
exact point of what?
Old Oct 30, 2009 | 06:42 AM
str8dum1's Avatar
str8dum1
ya you put the car back together, drive around the block, measure the gap, and adjust from there.
Old Nov 4, 2009 | 07:20 AM
labelworkshop75
yea just turn them all the same number of turns so all 4 have been adjusted equally. Put the car on the ground and measure distance from top of tire to fender. Make sure they are the same distances in rear. and same distances up front (front and rear can be dif. depending on height adjustment
350Z_Al
Oct 29, 2020 07:44 PM
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
Tochigi_236
Sep 27, 2015 03:40 PM
